メインコンテンツにスキップ
Hover-1 Charger LED Headlight Replacement
必要な工具と部品
  1. Hover-1 Charger LED Headlight Replacement, Unplugging the Battery: 手順 1、 2の画像 1 Hover-1 Charger LED Headlight Replacement, Unplugging the Battery: 手順 1、 2の画像 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger LED Headlight Replacement: 手順 2、 1の画像 1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger LED Headlight Replacement: 手順 3、 2の画像 1 Hover-1 Charger LED Headlight Replacement: 手順 3、 2の画像 2
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger LED Headlight Replacement: 手順 4、 1の画像 1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger LED Headlight Replacement: 手順 5、 2の画像 1 Hover-1 Charger LED Headlight Replacement: 手順 5、 2の画像 2
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger LED Headlight Replacement, LED Headlight: 手順 6、 2の画像 1 Hover-1 Charger LED Headlight Replacement, LED Headlight: 手順 6、 2の画像 2
    • Remove the black and red two pin connector from the circuitboard.
  7. Hover-1 Charger LED Headlight Replacement: 手順 7、 2の画像 1 Hover-1 Charger LED Headlight Replacement: 手順 7、 2の画像 2
    • Remove the two 12mm screws holding the LED to the front cover with a Phillips #2 screwdriver.
    • Our Hoverboard was missing a screw in the LED housing. Yours may or may not be missing screws as well.
  8. Hover-1 Charger LED Headlight Replacement: 手順 8、 1の画像 1
    • With the wire unplugged and screws removed, you can now safely seperate the LED from the Hoverboard.
終わりに
作成者
2人の作成者と共同で作成されました。
Benji Forest
メンバー登録日: 10/10/19
272 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S12-G1, Regan Fall 2019 Cal Poly, Team S12-G1, Regan Fall 2019人のメンバー
CPSU-REGAN-F19S12G1
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 319
