メインコンテンツにスキップ
Hover-1 Charger Gyroscope Sensor Board Replacement
必要な工具と部品
  1. Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: 手順 1、 2の画像 1 Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: 手順 1、 2の画像 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Gyroscope Sensor Board Replacement: 手順 2、 1の画像 1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger Gyroscope Sensor Board Replacement: 手順 3、 2の画像 1 Hover-1 Charger Gyroscope Sensor Board Replacement: 手順 3、 2の画像 2
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger Gyroscope Sensor Board Replacement: 手順 4、 1の画像 1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger Gyroscope Sensor Board Replacement: 手順 5、 2の画像 1 Hover-1 Charger Gyroscope Sensor Board Replacement: 手順 5、 2の画像 2
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: 手順 6、 3の画像 1 Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: 手順 6、 3の画像 2 Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: 手順 6、 3の画像 3
    • Unplug the white five pin connector from the gyroscope sensor board.
    • Unplug the red, yellow, blue, green, black and white six pin connector.
    • Unplug the black and red two pin connector.
    • Unplug the black, yellow, green and red four pin connector. Unplugging this connector is photographed as an example.
  7. Hover-1 Charger Gyroscope Sensor Board Replacement: 手順 7、 2の画像 1 Hover-1 Charger Gyroscope Sensor Board Replacement: 手順 7、 2の画像 2
    • Remove the four 10 mm screws from the gyroscope sensor board with a Phillips #2 screwdriver.
  8. Hover-1 Charger Gyroscope Sensor Board Replacement: 手順 8、 3の画像 1 Hover-1 Charger Gyroscope Sensor Board Replacement: 手順 8、 3の画像 2 Hover-1 Charger Gyroscope Sensor Board Replacement: 手順 8、 3の画像 3
    • Push the rubber sheaths away from the clasp of the green bullet connector.
    • Grasp the connector at the metal junction and disconnect.
    • Repeat for the yellow and red bullet connectors.
    • There may be a zip tie holding these wires together. Cut this off.
    • These bullet connectors may be hard to disconnect; do not be afraid to pull with strong force.
  9. Hover-1 Charger Gyroscope Sensor Board Replacement: 手順 9、 1の画像 1
    • Remove the gyroscope sensor board.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Melanie Hardell
メンバー登録日: 10/10/19
517 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S12-G1, Regan Fall 2019 Cal Poly, Team S12-G1, Regan Fall 2019人のメンバー
CPSU-REGAN-F19S12G1
4 メンバー
6のガイドは作成済み
4件のガイドコメント
Hi Where can I find the replacement sensor board? Thanks!
Jason LaDuke - 返信
where do i find the replacement sensor board?
one wheel of my board doesn’t work
Philip Donkoh - 返信
I need one of these replacement gyros please how I get
Matthew Isaiah Cowart - 返信
Worthless guide. No instructions on where to get the replacement gyro boards
Fuckaboi - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 56
今までの合計 5,750
