メインコンテンツにスキップ
Hover-1 Charger Bluetooth Speaker Replacement
必要な工具と部品
  1. Hover-1 Charger Bluetooth Speaker Replacement, Unplugging the Battery: 手順 1、 2の画像 1 Hover-1 Charger Bluetooth Speaker Replacement, Unplugging the Battery: 手順 1、 2の画像 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Bluetooth Speaker Replacement: 手順 2、 1の画像 1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger Bluetooth Speaker Replacement: 手順 3、 2の画像 1 Hover-1 Charger Bluetooth Speaker Replacement: 手順 3、 2の画像 2
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger Bluetooth Speaker Replacement: 手順 4、 1の画像 1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger Bluetooth Speaker Replacement: 手順 5、 2の画像 1 Hover-1 Charger Bluetooth Speaker Replacement: 手順 5、 2の画像 2
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger Bluetooth Speaker Replacement, Bluetooth Speaker: 手順 6、 1の画像 1
    • Locate the speaker attached to the left cover of the hoverboard.
  7. Hover-1 Charger Bluetooth Speaker Replacement: 手順 7、 2の画像 1 Hover-1 Charger Bluetooth Speaker Replacement: 手順 7、 2の画像 2
    • Unplug the red and white four pin connector from the circuit board. Unplugging this connector is photographed as an example.
    • Unplug the white and blue three pin connector from the circuit board.
    • Unplug the white and blue two pin connector from the circuit board.
  8. Hover-1 Charger Bluetooth Speaker Replacement: 手順 8、 2の画像 1 Hover-1 Charger Bluetooth Speaker Replacement: 手順 8、 2の画像 2
    • Using a Phillips #1 screwdriver, remove the two 7 mm screws from the circuit board.
  9. Hover-1 Charger Bluetooth Speaker Replacement: 手順 9、 2の画像 1 Hover-1 Charger Bluetooth Speaker Replacement: 手順 9、 2の画像 2
    • Using a Phillips #1 screwdriver, remove the three screws securing the speaker to the outer shell.
  10. Hover-1 Charger Bluetooth Speaker Replacement: 手順 10、 1の画像 1
    • Remove the speaker and circuit board from the outer shell.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Bryson Shishido
メンバー登録日: 10/10/19
145 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S12-G1, Regan Fall 2019 Cal Poly, Team S12-G1, Regan Fall 2019人のメンバー
CPSU-REGAN-F19S12G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 18
今までの合計 1,291
