メインコンテンツにスキップ
Hover-1 Charger Battery Replacement
必要な工具と部品
  1. Hover-1 Charger Battery Replacement, Battery: 手順 1、 2の画像 1 Hover-1 Charger Battery Replacement, Battery: 手順 1、 2の画像 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Battery Replacement: 手順 2、 1の画像 1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger Battery Replacement: 手順 3、 2の画像 1 Hover-1 Charger Battery Replacement: 手順 3、 2の画像 2
    • Unplug the battery by disconnecting the two pronged black and yellow cable.
  4. Hover-1 Charger Battery Replacement: 手順 4、 1の画像 1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger Battery Replacement: 手順 5、 2の画像 1 Hover-1 Charger Battery Replacement: 手順 5、 2の画像 2
    • Disconnect the two pronged black and yellow cable.
    • Thread the cable through the middle cylinder of the hoverboard.
  6. Hover-1 Charger Battery Replacement: 手順 6、 2の画像 1 Hover-1 Charger Battery Replacement: 手順 6、 2の画像 2
    • Unscrew the four 10mm screws that are holding the battery casing in place. Use a Phillips #2 screwdriver.
    • If there is a zip-tie connecting the wires together, carefully cut it with a wire cutters.
  7. Hover-1 Charger Battery Replacement: 手順 7、 3の画像 1 Hover-1 Charger Battery Replacement: 手順 7、 3の画像 2 Hover-1 Charger Battery Replacement: 手順 7、 3の画像 3
    • On the battery side, unplug the white five pin connector on the circuitboard.
    • Unplug the black, yellow, green and red connector on the circuitboard.
  8. Hover-1 Charger Battery Replacement: 手順 8、 1の画像 1
    • Move all the loose cables to the side. Pull the battery casing away from the battery.
  9. Hover-1 Charger Battery Replacement: 手順 9、 1の画像 1
    • Use the opening tool to remove the battery from the metal casing.
    • The battery is stuck to the metal casing with strong adhesive; do not be afraid to apply a strong force with the opening tool.
  10. Hover-1 Charger Battery Replacement: 手順 10、 1の画像 1
    • Remove the battery.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Melanie Hardell
メンバー登録日: 10/10/19
505 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S12-G1, Regan Fall 2019 Cal Poly, Team S12-G1, Regan Fall 2019人のメンバー
CPSU-REGAN-F19S12G1
4 メンバー
6のガイドは作成済み
コメント 1 件
Can I replace my battery 25.2v to a 36v.
Airie Green - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 56
過去 30 日: 188
今までの合計 6,948
