はじめに
This guide shows how to remove and replace the starter battery for the Honda EU3000IS1AWK 3000 watt generator.
Some images in this guide may show the lower plate removed from the generator. You do not need to remove the lower plate for this procedure.
Before you begin, make sure the generator is switched off and the generator is cool to the touch.
必要な工具と部品
Use a 10 mm socket to remove the four capped nuts securing the front cover.
Remove the front cover.
Use an 8 mm socket to disconnect the battery wires from the battery terminals.
Disconnect the black negative cable first to prevent the risk of shorting the battery.
3 の人々がこのガイドを完成させました。
