メインコンテンツにスキップ
Heyday Wireless Speaker 8125 Battery Replacement
必要な工具と部品
  1. Heyday Wireless Speaker 8125 Battery Replacement, Grille: 手順 1、 3の画像 1 Heyday Wireless Speaker 8125 Battery Replacement, Grille: 手順 1、 3の画像 2 Heyday Wireless Speaker 8125 Battery Replacement, Grille: 手順 1、 3の画像 3
    • Orient the speaker so that it is sitting upright.
    • Use your nondominant hand to hold the speaker in place while you firmly push the plastic spudger into the seam between the device wall and the grille.
    • Push down with the plastic spudger and lift the grill until you feel it separate from the speaker.
    • Gently remove it from the top of the device.
  2. Heyday Wireless Speaker 8125 Battery Replacement, Black Plastic Cover: 手順 2、 2の画像 1 Heyday Wireless Speaker 8125 Battery Replacement, Black Plastic Cover: 手順 2、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use tweezers to remove the four black rubber screw covers.
    • Use a Phillips screwdriver to remove four 8.9 mm screws underneath the screw covers.
    • Once all four screws are out, gently pull the black cover out using your hands or use a spudger to pry it out.
    • The cover is attached to the motherboard beneath by the speaker cable. Don't yank the cover from the device. You will need to detach the connector from the socket before removing it entirely.
  3. Heyday Wireless Speaker 8125 Battery Replacement, Motherboard: 手順 3、 3の画像 1 Heyday Wireless Speaker 8125 Battery Replacement, Motherboard: 手順 3、 3の画像 2 Heyday Wireless Speaker 8125 Battery Replacement, Motherboard: 手順 3、 3の画像 3
    • Use a Phillips screwdriver to remove four 6.6 mm screws from the motherboard.
    • Lift the motherboard out of the speaker gently.
    • It's attached below by a couple of cables, so don't pull it out.
  4. Heyday Wireless Speaker 8125 Battery Replacement: 手順 4、 2の画像 1 Heyday Wireless Speaker 8125 Battery Replacement: 手順 4、 2の画像 2
    • Pull each cable away from the connector in the same direction that the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Remove the motherboard from the device.
  5. Heyday Wireless Speaker 8125 Battery Replacement, Battery: 手順 5、 2の画像 1 Heyday Wireless Speaker 8125 Battery Replacement, Battery: 手順 5、 2の画像 2
    • Use a Phillips screwdriver to remove three 6.6 mm screws from the triangular plastic support.
    • Lift the plastic support to reveal the battery underneath.
  6. Heyday Wireless Speaker 8125 Battery Replacement: 手順 6、 2の画像 1 Heyday Wireless Speaker 8125 Battery Replacement: 手順 6、 2の画像 2
    • Use an opening tool or plastic spudger to gently pry the battery from the bottom of the device.
    • The battery is held down with adhesive so it will take a bit of work to remove.
    • Don't bend or puncture the battery in the process. Batteries can cause a fire or worse if damaged.
    • Remove the battery.
終わりに
作成者
3人の作成者と共同で作成されました。
Mariah Perfect
メンバー登録日: 01/20/23
147 ポイント
1ガイドが承認済み
チーム
Linn Benton Community College, Team 1-1, Karnes Winter 2023 Linn Benton Community College, Team 1-1, Karnes Winter 2023人のメンバー
LBCC-KARNES-W23S1G1
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 11
今までの合計 334
