メインコンテンツにスキップ
Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement
必要な工具と部品
  1. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement, Back Panel: 手順 1、 1の画像 1
    • Place the tablet screen side up.
    • Make sure the device is turned off to avoid damage.
  2. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 手順 2、 2の画像 1 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 手順 2、 2の画像 2
    • Use the metal spudger to press an opening between the screen and back cover.
    • The plastic tabs are located on each corner of the back cover.
    • Be careful, as the plastic tabs are delicate.
  3. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 手順 3、 1の画像 1
    • Wedge the plastic opening tool between the screen and the back panel to prevent re-engagement
  4. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 手順 4、 2の画像 1 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 手順 4、 2の画像 2
    • Slide the metal spudger around the casing to separate it from the inside of the tablet.
  5. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 手順 5、 2の画像 1 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 手順 5、 2の画像 2
    • Flip the tablet over so the screen side is down after all the tabs are separated.
    • Remove the back panel by delicately lifting it straight up.
  6. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement, Battery: 手順 6、 2の画像 1 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement, Battery: 手順 6、 2の画像 2
    • Remove the adhesive tape from the power connection cables.
  7. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 手順 7、 3の画像 1 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 手順 7、 3の画像 2 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 手順 7、 3の画像 3
    この手順で使用する道具:
    購入する
    • Instructions for desoldering can be found on the iFixit website.
    • The soldering iron is hot. It can burn you and it can cause damage to the wires and motherboard.
    • Grab hold of the red wire using the tweezers.
    • Desolder the red wire connection from the motherboard using the tip of the soldering iron.
    • Move the wire connection away from the motherboard.
    • Do not let the red wire connection touch other wires or the motherboard.
  8. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 手順 8、 3の画像 1 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 手順 8、 3の画像 2 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 手順 8、 3の画像 3
    • Desolder the black and yellow wire connection from the motherboard by following the previous step.
    • When moving the wire connections, do not let the red wire connection touch other wires or the motherboard.
  9. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 手順 9、 3の画像 1 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 手順 9、 3の画像 2 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 手順 9、 3の画像 3
    • Insert the flat end of the nylon spudger between the battery and the case.
    • The battery is connected to the tablet with an adhesive tape and will come free slowly.
    • Do not puncture or bend the battery while removing. If your battery is swollen, take appropriate precautions.
  10. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement, Front and Rear Camera Replacement: 手順 10、 2の画像 1 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement, Front and Rear Camera Replacement: 手順 10、 2の画像 2
    • Identify the ribbon connecter attached to the camera and where it connects to the circuit board.
    • The two cameras are connected with one ribbon cable.
    • Zero insertion force connector.
  11. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 手順 11、 3の画像 1 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 手順 11、 3の画像 2 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 手順 11、 3の画像 3
    • Disconnect the sliding zero insertion force (ZIF). Use the plastic opening tool or a fingernail to slide the tab out, then pull the cable out.
  12. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 手順 12、 3の画像 1 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 手順 12、 3の画像 2 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 手順 12、 3の画像 3
    • Pull the cameras out of their resting places in a straight upward motion.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
matthew vandeventer
メンバー登録日: 03/11/15
950 ポイント
5のガイドは作成済み
チーム
Colorado Springs, Team 9-4, Panko Spring 2015 Colorado Springs, Team 9-4, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S9G4
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 609
