この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
You will be able to use this guide as long as you know how to use a screwdriver.
必要な工具と部品
Open the Visor Edge and place it on a table facing down.
Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
もう少しです!
終わりに
