Open the Visor Edge and place it on a table facing down.
Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
Do not pull on the flip cover in an attempt to remove it from the PDA.
Using the tweezers, pull back the ribbon cable on the top of the device.
Pull at the white part of the ribbon to avoid tearing.
Carefully separate the circuit board and the screen. (Be careful of soldered wires when separating)
Be careful not to break the soldered wires that connects the circuit board to the battery pack.
Disconnect the wire that connects the battery pack to the motherboard using tweezers.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
