メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
Handspring Visor Edge Battery Replacement
必要な工具と部品
  1. Handspring Visor Edge Battery Replacement, Flip Cover: 手順 1、 2の画像 1 Handspring Visor Edge Battery Replacement, Flip Cover: 手順 1、 2の画像 2
    • Open the Visor Edge and place it on a table facing down.
    • Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
    • Do not pull on the flip cover in an attempt to remove it from the PDA.
  2. Handspring Visor Edge Battery Replacement, Back Panel: 手順 2、 1の画像 1
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Battery Replacement: 手順 3、 1の画像 1
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Battery Replacement: 手順 4、 2の画像 1 Handspring Visor Edge Battery Replacement: 手順 4、 2の画像 2
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Battery Replacement: 手順 5、 2の画像 1 Handspring Visor Edge Battery Replacement: 手順 5、 2の画像 2
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Battery Replacement: 手順 6、 1の画像 1
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Battery Replacement, Battery: 手順 7、 1の画像 1
    • Pull front cover off gently.
  8. Handspring Visor Edge Battery Replacement: 手順 8、 2の画像 1 Handspring Visor Edge Battery Replacement: 手順 8、 2の画像 2
    • Using your finger or tweezers, carefully push back the brown lock holding the ribbon cable on the side of the circuit board.
    • Remove the ribbon cable with tweezers.
  9. Handspring Visor Edge Battery Replacement: 手順 9、 1の画像 1
    • Using the tweezers, pull back the ribbon cable on the top of the device.
    • Pull by white part of the ribbon to avoid tearing.
  10. Handspring Visor Edge Battery Replacement: 手順 10、 1の画像 1
    • Using the same technique as with the other ribbons, locate and remove the ribbon cable above the battery pack.
  11. Handspring Visor Edge Battery Replacement: 手順 11、 1の画像 1
    • All the ribbon cables should be disconnected from the mother board.
    • Remove the four 3.6 mm Philips screws at each corner of the device.
  12. Handspring Visor Edge Battery Replacement: 手順 12、 2の画像 1 Handspring Visor Edge Battery Replacement: 手順 12、 2の画像 2
    • Carefully separate the circuit board and the screen.
    • The circuit board isn't fully disconnected, be sure to not break the soldered wires connecting both components.
    • Remove the wire connecting the battery pack to the motherboard using tweezers.
  13. Handspring Visor Edge Battery Replacement: 手順 13、 2の画像 1 Handspring Visor Edge Battery Replacement: 手順 13、 2の画像 2
    • The battery is stuck on by an adhesive, wedge the spudger under the battery and pry apart.
終わりに
作成者
8人の作成者と共同で作成されました。
Christian Valoria
メンバー登録日: 01/23/11
201 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 11-28, Maness Winter 2011 Cal Poly, Team 11-28, Maness Winter 2011人のメンバー
CPSU-MANESS-W11S11G28
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 34
今までの合計 3,159
