メインコンテンツにスキップ
Handset Speaker Replacement
必要な工具と部品
  1. Handset Speaker Replacement, Handset: 手順 1、 1の画像 1
    • After removing the BP-T18 battery pack, you will see two 11mm Phillips #0 screws located at the bottom of the phone. Remove both screws with a screwdriver.
    • Product is made of brittle plastic.
  2. Handset Speaker Replacement: 手順 2、 2の画像 1 Handset Speaker Replacement: 手順 2、 2の画像 2
    • Locate an easy point of access for a spudger, and then slowly insert it into the gap and pry it open.
    • The opening should become bigger if you exert force at a 30 degrees angle.
    • Increase the degree of slant until the back cover is completely removed.
  3. Handset Speaker Replacement: 手順 3、 2の画像 1 Handset Speaker Replacement: 手順 3、 2の画像 2
    • After removing the back cover, you will see 3 screws: one 7mm Phillips #0 screw at the top and two 11mm Phillips #0 screws at the bottom.
    • Use a screwdriver to remove all 3 screws.
  4. Handset Speaker Replacement, Handset Speaker: 手順 4、 1の画像 1
    • After disassembling the handset, you will see a circular component at the top section of the handset. This is your speaker.
    • Use a screwdriver to remove the three 7mm Phillips #0 screws holding the speaker in place.
  5. Handset Speaker Replacement: 手順 5、 1の画像 1
    • Gently pull out the speaker and inspect it.
    • Determine if the handset speaker is damaged and needs replaced. Replacement requires soldering.
    • Finish removing a faulty speaker by cutting the two wires connecting it to the circuit board.
  6. Handset Speaker Replacement: 手順 6、 1の画像 1
    • Solder the replacement speaker in the circuit board. For information on how-to-solder check iFixit's Solder and Desolder Guide by clicking the blue link below.
終わりに
作成者
2人の作成者と共同で作成されました。
Han Shih
メンバー登録日: 09/29/16
361 ポイント
4のガイドは作成済み
チーム
IUPUI, Team 3-3, Harley Fall 2016 IUPUI, Team 3-3, Harley Fall 2016人のメンバー
IUPUI-HARLEY-F16S3G3
4 メンバー
17のガイドは作成済み
コメント 1 件
What shall I look for speaker is not working?
naila ilyas - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 12
今までの合計 710
