メインコンテンツにスキップ
HTC Vive XR Elite Face Cover Replacement
必要な工具と部品
  1. HTC Vive XR Elite Face Cover Replacement, Prepare your Vive XR Elite for disassembly: 手順 1、 1の画像 1
    • Before starting this repair, discharge the batteries in your headset below 25%. A charged battery may leak dangerous chemicals or catch fire if damaged.
    • Playing Half Life: Alyx will do the trick!
    • The Vive XR Elite has a proximity sensor that puts the headset in standby mode to save battery when it isn't in use. To drain the battery faster you'll need to use the headset.
  2. HTC Vive XR Elite Face Cover Replacement, Disconnect the USB-C power cable: 手順 2、 2の画像 1 HTC Vive XR Elite Face Cover Replacement, Disconnect the USB-C power cable: 手順 2、 2の画像 2
    • Disconnect the USB-C power cable.
  3. HTC Vive XR Elite Face Cover Replacement, Disconnect the battery cradle: 手順 3、 3の画像 1 HTC Vive XR Elite Face Cover Replacement, Disconnect the battery cradle: 手順 3、 3の画像 2 HTC Vive XR Elite Face Cover Replacement, Disconnect the battery cradle: 手順 3、 3の画像 3
    • Press the release button on the right battery cradle temple slot.
    • Pull the battery cradle away from the right temple slot to disconnect it.
  4. HTC Vive XR Elite Face Cover Replacement: 手順 4、 3の画像 1 HTC Vive XR Elite Face Cover Replacement: 手順 4、 3の画像 2 HTC Vive XR Elite Face Cover Replacement: 手順 4、 3の画像 3
    • Repeat the previous step for the left temple slot.
  5. HTC Vive XR Elite Face Cover Replacement, Separate the headset and battery cradle: 手順 5、 1の画像 1
    • Separate the headset and battery cradle.
  6. HTC Vive XR Elite Face Cover Replacement, Remove the face cushion: 手順 6、 3の画像 1 HTC Vive XR Elite Face Cover Replacement, Remove the face cushion: 手順 6、 3の画像 2 HTC Vive XR Elite Face Cover Replacement, Remove the face cushion: 手順 6、 3の画像 3
    • The face cushion is attached to the headset with two magnets. You'll feel the pull of the magnets as you remove it.
    • Grip the middle of the face cushion with your fingers and pull back to remove it.
  7. HTC Vive XR Elite Face Cover Replacement, Remove the screw covers: 手順 7、 2の画像 1 HTC Vive XR Elite Face Cover Replacement, Remove the screw covers: 手順 7、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use tweezers to remove the six screw covers from the right temple.
  8. HTC Vive XR Elite Face Cover Replacement, Unfasten the right temple: 手順 8、 2の画像 1 HTC Vive XR Elite Face Cover Replacement, Unfasten the right temple: 手順 8、 2の画像 2
    • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two right temple halves.
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the right hinge cover.
  9. HTC Vive XR Elite Face Cover Replacement, Remove the outer hinge cover: 手順 9、 3の画像 1 HTC Vive XR Elite Face Cover Replacement, Remove the outer hinge cover: 手順 9、 3の画像 2 HTC Vive XR Elite Face Cover Replacement, Remove the outer hinge cover: 手順 9、 3の画像 3
    • Insert the flat end of a spudger in the gap between the right outer and inner hinge covers.
    • Slide the spudger along the gap to separate the clips securing the outer hinge cover.
    • Remove the outer hinge cover.
  10. HTC Vive XR Elite Face Cover Replacement, Remove the outer temple: 手順 10、 3の画像 1 HTC Vive XR Elite Face Cover Replacement, Remove the outer temple: 手順 10、 3の画像 2 HTC Vive XR Elite Face Cover Replacement, Remove the outer temple: 手順 10、 3の画像 3
    • Insert the flat end of a spudger in the gap between the outer and inner temple.
    • Slide the spudger along the gap to separate the clips securing the outer temple.
  11. HTC Vive XR Elite Face Cover Replacement: 手順 11、 3の画像 1 HTC Vive XR Elite Face Cover Replacement: 手順 11、 3の画像 2 HTC Vive XR Elite Face Cover Replacement: 手順 11、 3の画像 3
    • Slide the top of the outer temple out of its slot in the hinge.
  12. HTC Vive XR Elite Face Cover Replacement: 手順 12、 2の画像 1 HTC Vive XR Elite Face Cover Replacement: 手順 12、 2の画像 2
    この手順で使用する道具:
    Tesa 61395 Tape
    $6.99
    購入する
    • The speaker is lightly adhered to the outer temple.
    • Rotate the outer temple towards you to access the speaker.
    • Slide the flat end of a spudger under the speaker to separate its adhesive.
    • During reassembly, if your speaker adhesive isn't sticky, use double-sided tape to re-adhere the speaker to the outer temple.
  13. HTC Vive XR Elite Face Cover Replacement: 手順 13、 3の画像 1 HTC Vive XR Elite Face Cover Replacement: 手順 13、 3の画像 2 HTC Vive XR Elite Face Cover Replacement: 手順 13、 3の画像 3
    • Thread the outer temple off of the USB‑C cable and remove it.
  14. HTC Vive XR Elite Face Cover Replacement: 手順 14、 2の画像 1 HTC Vive XR Elite Face Cover Replacement: 手順 14、 2の画像 2
    • Pull the inner temple out of its slot in the hinge and remove it.
  15. HTC Vive XR Elite Face Cover Replacement, Peel the hinge tape: 手順 15、 2の画像 1 HTC Vive XR Elite Face Cover Replacement, Peel the hinge tape: 手順 15、 2の画像 2
    • Use tweezers to peel back the black tape covering one of the inner hinge cover screws.
  16. HTC Vive XR Elite Face Cover Replacement, Unfasten the inner hinge cover: 手順 16、 1の画像 1
    • Use a T5 Torx screwdriver to remove the two screws securing the inner hinge cover:
    • One 3.1 mm‑long screw
    • One 4.9 mm‑long screw
  17. HTC Vive XR Elite Face Cover Replacement, Remove the inner hinge cover: 手順 17、 3の画像 1 HTC Vive XR Elite Face Cover Replacement, Remove the inner hinge cover: 手順 17、 3の画像 2 HTC Vive XR Elite Face Cover Replacement, Remove the inner hinge cover: 手順 17、 3の画像 3
    • Rotate the inner hinge cover off its groove in the frame.
    • Thread the inner hinge cover off of the USB-C and speaker cables and remove it.
  18. HTC Vive XR Elite Face Cover Replacement, Remove the screw covers: 手順 18、 2の画像 1 HTC Vive XR Elite Face Cover Replacement, Remove the screw covers: 手順 18、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use tweezers to remove the six screw covers from the left temple.
  19. HTC Vive XR Elite Face Cover Replacement, Unfasten the left temple: 手順 19、 2の画像 1 HTC Vive XR Elite Face Cover Replacement, Unfasten the left temple: 手順 19、 2の画像 2
    • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two left temple halves.
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the left hinge cover.
  20. HTC Vive XR Elite Face Cover Replacement, Remove the outer hinge cover: 手順 20、 3の画像 1 HTC Vive XR Elite Face Cover Replacement, Remove the outer hinge cover: 手順 20、 3の画像 2 HTC Vive XR Elite Face Cover Replacement, Remove the outer hinge cover: 手順 20、 3の画像 3
    • Insert the flat end of a spudger in the gap between the left outer and inner hinge covers.
  21. HTC Vive XR Elite Face Cover Replacement, Remove the left temple: 手順 21、 2の画像 1 HTC Vive XR Elite Face Cover Replacement, Remove the left temple: 手順 21、 2の画像 2
    • Pull the left temple out of its slot in the hinge.
    • Don't try to fully remove it yet, as it's still connected by a cable.
  22. HTC Vive XR Elite Face Cover Replacement: 手順 22、 2の画像 1 HTC Vive XR Elite Face Cover Replacement: 手順 22、 2の画像 2
    • Slide the spudger along the gap to separate the plastic clips securing the outer temple.
  23. HTC Vive XR Elite Face Cover Replacement: 手順 23、 2の画像 1 HTC Vive XR Elite Face Cover Replacement: 手順 23、 2の画像 2
    • Pull the outer temple off of its inner half to completely release its plastic clips.
  24. HTC Vive XR Elite Face Cover Replacement: 手順 24、 2の画像 1 HTC Vive XR Elite Face Cover Replacement: 手順 24、 2の画像 2
    この手順で使用する道具:
    Tesa 61395 Tape
    $6.99
    購入する
    • Let the speaker rest next to the headset before continuing.
    • During reassembly, if your speaker adhesive isn't sticky, use Tesa 61395 Tape to re-adhere the speaker to the outer temple.
  25. HTC Vive XR Elite Face Cover Replacement, Peel the hinge tape: 手順 25、 2の画像 1 HTC Vive XR Elite Face Cover Replacement, Peel the hinge tape: 手順 25、 2の画像 2
  26. HTC Vive XR Elite Face Cover Replacement, Unfasten the inner hinge cover: 手順 26、 1の画像 1
    • One 3.5 mm‑long screw
  27. HTC Vive XR Elite Face Cover Replacement, Reposition the inner hinge cover: 手順 27、 3の画像 1 HTC Vive XR Elite Face Cover Replacement, Reposition the inner hinge cover: 手順 27、 3の画像 2 HTC Vive XR Elite Face Cover Replacement, Reposition the inner hinge cover: 手順 27、 3の画像 3
    • Don't fully remove the inner hinge cover, as it's connected by the volume button cable.
    • Let the cover hang off its volume button cable for now.
  28. HTC Vive XR Elite Face Cover Replacement, Unfasten the face plate: 手順 28、 2の画像 1 HTC Vive XR Elite Face Cover Replacement, Unfasten the face plate: 手順 28、 2の画像 2
    • Use a T5 Torx screwdriver to remove the 12 screws securing the face plate:
    • Six 3.5 mm‑long screws
    • Four 4.9 mm‑long screws
    • Two 6.5 mm‑long screws
    • There are two magnets at the top corners of the face plate. As you remove nearby screws, they might stick to them.
  29. HTC Vive XR Elite Face Cover Replacement, Unclip the face cover: 手順 29、 2の画像 1 HTC Vive XR Elite Face Cover Replacement, Unclip the face cover: 手順 29、 2の画像 2
    • Insert the flat end of the spudger in the gap between the frame and the bottom right corner of the face cover.
    • Pry up with the spudger to release the clips securing the face cover.
  30. HTC Vive XR Elite Face Cover Replacement: 手順 30、 2の画像 1 HTC Vive XR Elite Face Cover Replacement: 手順 30、 2の画像 2
    • Repeat the prying process for the middle and bottom left portions of the face cover.
  31. HTC Vive XR Elite Face Cover Replacement, Reposition the face cover: 手順 31、 3の画像 1 HTC Vive XR Elite Face Cover Replacement, Reposition the face cover: 手順 31、 3の画像 2 HTC Vive XR Elite Face Cover Replacement, Reposition the face cover: 手順 31、 3の画像 3
    • Don't fully remove the face cover completely, as it's connected by the proximity sensor cable.
    • Lift the face cover and rotate it over the top of the frame.
    • Lay the face cover face up before continuing.
  32. HTC Vive XR Elite Face Cover Replacement, Unfasten the proximity sensor: 手順 32、 1の画像 1
    • Use a T5 Torx screwdriver to remove the two 3.3 mm‑long screws securing the proximity sensor cable.
  33. HTC Vive XR Elite Face Cover Replacement, Remove the face cover: 手順 33、 2の画像 1 HTC Vive XR Elite Face Cover Replacement, Remove the face cover: 手順 33、 2の画像 2
    • Remove the face cover.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
作成者
1人の作成者と共同作成されました。
Alex Diaz-Kokaisl
メンバー登録日: 01/16/22
125,037 ポイント
582のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,430のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 189
