はじめに
Use this guide to replace the head strap on an HTC Vive.
必要な工具と部品
Pull the hook-and-loop (Velcro) closure at the top of the head strap apart to release the top of the head strap.
Slide the top part of the head strap through its metal loop on the headset to remove it.
Pull the hook-and-loop closure at the right side of the head strap apart to release the right side of the head strap.
Slide the right side of the head strap through its metal loop to remove it.
Pull the hook-and-loop closure at the left side of the head strap apart to release the left side of the head strap.
Slide the left side of the head strap through its metal loop to remove it.
Slide the head strap along the cable, away from the Vive.
When the head strap comes to the end of the cable, gently slide it over the plugs and remove it.
6 の人々がこのガイドを完成させました。
3 件のコメント
What is the name of the Part that holds the strap and has VIVE written on it ? Can I order that part individually ?
You can find that part, as well as the center strap holder by searching on eBay for HTC Vive headset parts. I’ve attached a link here: https://www.ebay.com/itm/Genuine-HTC-VIV...
how to fix my headset strap on my vive i nead some help on it can you show me how.
