はじめに
Use this guide to remove and replace the focus knob on an HTC Vive.
必要な工具と部品
Use tweezers to remove the small stickers over the four screws securing the outer shell.
Use a T5 Torx driver to remove the four 3.4 mm-long screws securing the outer shell.
Use the flat end of a spudger to pry up the top edge of the right half of the outer shell, behind the component cover and near the seam in the center, until it is unclipped from the headset.
ある他の人がこのガイドを完成しました。
