メインコンテンツにスキップ
HTC Vive Focus CPU Fan Replacement
必要な工具と部品
  1. HTC Vive Focus CPU Fan Replacement, Remove the facerest cushion: 手順 1、 3の画像 1 HTC Vive Focus CPU Fan Replacement, Remove the facerest cushion: 手順 1、 3の画像 2 HTC Vive Focus CPU Fan Replacement, Remove the facerest cushion: 手順 1、 3の画像 3
    • Place your device upside-down on your work surface.
    • The facerest cushion is lightly held into place by seven plastic clips.
    • Use your fingers to gently pull the facerest cushion straight off of the facerest to remove it.
  2. HTC Vive Focus CPU Fan Replacement, Remove the facerest: 手順 2、 1の画像 1
    • Use a T5 Torx screwdriver to remove the eight 4.5 mm screws securing the facerest.
    • One of the screws will be covered by a tamper-evident sticker. Press the driver through the sticker to remove the screw.
  3. HTC Vive Focus CPU Fan Replacement: 手順 3、 3の画像 1 HTC Vive Focus CPU Fan Replacement: 手順 3、 3の画像 2 HTC Vive Focus CPU Fan Replacement: 手順 3、 3の画像 3
    • Insert an opening pick into the upper-left corner of the facerest.
    • Twist the opening pick to release the plastic clip securing the facerest.
    • Repeat for the upper-right corner.
    • Don't remove the facerest yet. It's still attached by the facerest sensor ribbon cable.
  4. HTC Vive Focus CPU Fan Replacement, Remove the facerest sensor: 手順 4、 3の画像 1 HTC Vive Focus CPU Fan Replacement, Remove the facerest sensor: 手順 4、 3の画像 2 HTC Vive Focus CPU Fan Replacement, Remove the facerest sensor: 手順 4、 3の画像 3
    • Carefully flip your device over.
    • Pull the facerest out just enough to access the screws securing the facerest sensor.
    • Don't put any strain on the facerest sensor ribbon cable.
    • During reassembly, make sure the facerest sensor ribbon cable is positioned between the lenses before reinstalling the facerest.
  5. HTC Vive Focus CPU Fan Replacement: 手順 5、 1の画像 1
    • Use a T5 Torx screwdriver to remove the two 2.4 mm screws securing the facerest sensor to the facerest.
  6. HTC Vive Focus CPU Fan Replacement: 手順 6、 1の画像 1
    • Remove the facerest.
  7. HTC Vive Focus CPU Fan Replacement, Unscrew the front cover: 手順 7、 2の画像 1 HTC Vive Focus CPU Fan Replacement, Unscrew the front cover: 手順 7、 2の画像 2
    • Use your fingers to slide the lenses towards each other so that they are positioned towards the center of the device.
  8. HTC Vive Focus CPU Fan Replacement: 手順 8、 2の画像 1 HTC Vive Focus CPU Fan Replacement: 手順 8、 2の画像 2
    • Use a T5 Torx screwdriver to remove the four screws securing the front cover from inside the device:
    • Two 5.7 mm screws with fine threads
    • Two 5.5 mm screws with coarse threads
    • The coarse-thread screws can strip easily. During reassembly, tighten the coarse-thread screws until they're hand tight and then no more.
  9. HTC Vive Focus CPU Fan Replacement, Remove the front cover: 手順 9、 2の画像 1 HTC Vive Focus CPU Fan Replacement, Remove the front cover: 手順 9、 2の画像 2
    • Note the location of the plastic welds on both vertical edges of the front cover.
    • After reassembly, the gap between the front cover and the side panels may no longer be flush. This is a cosmetic defect only and will not affect operation. The front cover's clips and screws are sufficient to secure it to the rest of the device.
  10. HTC Vive Focus CPU Fan Replacement: 手順 10、 3の画像 1 HTC Vive Focus CPU Fan Replacement: 手順 10、 3の画像 2 HTC Vive Focus CPU Fan Replacement: 手順 10、 3の画像 3
    • Insert an opening pick into the top of the front cover near the upper left corner.
    • Slide the opening pick around the upper left corner of the front cover.
  11. HTC Vive Focus CPU Fan Replacement: 手順 11、 2の画像 1 HTC Vive Focus CPU Fan Replacement: 手順 11、 2の画像 2
    • Use the opening pick to separate the weld securing the left side vertical edge of the front cover.
    • The weld may require significant force to separate.
  12. HTC Vive Focus CPU Fan Replacement: 手順 12、 3の画像 1 HTC Vive Focus CPU Fan Replacement: 手順 12、 3の画像 2 HTC Vive Focus CPU Fan Replacement: 手順 12、 3の画像 3
    • Insert an opening pick into the top of the front cover near the upper right corner.
    • Slide the opening pick around the upper right corner of the front cover.
  13. HTC Vive Focus CPU Fan Replacement: 手順 13、 2の画像 1 HTC Vive Focus CPU Fan Replacement: 手順 13、 2の画像 2
    • Use the opening pick to separate the weld securing the right side vertical edge of the front cover.
  14. HTC Vive Focus CPU Fan Replacement: 手順 14、 3の画像 1 HTC Vive Focus CPU Fan Replacement: 手順 14、 3の画像 2 HTC Vive Focus CPU Fan Replacement: 手順 14、 3の画像 3
    • Flip the device upside-down.
    • Use an opening pick to disconnect the plastic clips securing the bottom right edge of the front cover to the device.
  15. HTC Vive Focus CPU Fan Replacement: 手順 15、 2の画像 1 HTC Vive Focus CPU Fan Replacement: 手順 15、 2の画像 2
    • Slide the opening pick along the bottom edge of the front cover to separate it from the device.
  16. HTC Vive Focus CPU Fan Replacement: 手順 16、 2の画像 1 HTC Vive Focus CPU Fan Replacement: 手順 16、 2の画像 2
    • Use the opening pick to disconnect the plastic clips securing the bottom-left edge of the front cover to the device.
  17. HTC Vive Focus CPU Fan Replacement: 手順 17、 2の画像 1 HTC Vive Focus CPU Fan Replacement: 手順 17、 2の画像 2
    • Flip the device right-side up.
    • Use the opening pick to separate the last few plastic clips securing the top of the front cover.
  18. HTC Vive Focus CPU Fan Replacement: 手順 18、 2の画像 1 HTC Vive Focus CPU Fan Replacement: 手順 18、 2の画像 2
    • Remove the front cover.
  19. HTC Vive Focus CPU Fan Replacement, Remove the CPU fan: 手順 19、 3の画像 1 HTC Vive Focus CPU Fan Replacement, Remove the CPU fan: 手順 19、 3の画像 2 HTC Vive Focus CPU Fan Replacement, Remove the CPU fan: 手順 19、 3の画像 3
    この手順で使用する道具:
    $3.99
    購入する
    • Use a pair of angled tweezers to disconnect the CPU fan cable from the motherboard.
    • Lift the CPU fan connector straight up from the motherboard to disconnect it from its socket.
    • During reassembly, align the CPU fan connector with its socket and use your finger to press it straight down into the motherboard.
  20. HTC Vive Focus CPU Fan Replacement: 手順 20、 2の画像 1 HTC Vive Focus CPU Fan Replacement: 手順 20、 2の画像 2
    • Use a T5 Torx screwdriver to remove the three 5.5 mm screws securing the CPU fan.
    • Use a Phillips screwdriver to remove the two 2.3 mm screws securing the CPU heatsink.
  21. HTC Vive Focus CPU Fan Replacement: 手順 21、 2の画像 1 HTC Vive Focus CPU Fan Replacement: 手順 21、 2の画像 2
    • Remove the CPU fan.
    • During reassembly, do not sandwich the red antenna cable between the heatsink and contact plates.
終わりに
作成者
2人の作成者と共同で作成されました。
Sam Omiotek
メンバー登録日: 02/25/19
73,663 ポイント
288のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 6
今までの合計 205
