メインコンテンツにスキップ
HTC Vive Cosmos Headstrap Hinge Replacement
必要な工具と部品
  1. HTC Vive Cosmos Headstrap Hinge Replacement, Remove the facerest: 手順 1、 3の画像 1 HTC Vive Cosmos Headstrap Hinge Replacement, Remove the facerest: 手順 1、 3の画像 2 HTC Vive Cosmos Headstrap Hinge Replacement, Remove the facerest: 手順 1、 3の画像 3
    • Pull the bottom of the facerest straight away from the Vive Cosmos to unclip it from the Vive.
    • With the bottom unclipped, pull the top of the facerest away from the Vive to remove it.
  2. HTC Vive Cosmos Headstrap Hinge Replacement, Unplug the audio connector: 手順 2、 3の画像 1 HTC Vive Cosmos Headstrap Hinge Replacement, Unplug the audio connector: 手順 2、 3の画像 2 HTC Vive Cosmos Headstrap Hinge Replacement, Unplug the audio connector: 手順 2、 3の画像 3
    • Twist the 3.5 mm audio connector counter-clockwise slightly and slide its cable out from under the plastic retaining clip.
    • Lift the audio connector straight up to unplug it.
  3. HTC Vive Cosmos Headstrap Hinge Replacement, Remove the front headstrap pad: 手順 3、 3の画像 1 HTC Vive Cosmos Headstrap Hinge Replacement, Remove the front headstrap pad: 手順 3、 3の画像 2 HTC Vive Cosmos Headstrap Hinge Replacement, Remove the front headstrap pad: 手順 3、 3の画像 3
    • Grasp one end of the front headstrap pad and pull it away from the headstrap to remove it.
    • During reassembly, press the pads firmly against the headstrap, starting in the middle and moving toward the edges, until all the clips on the pads are completely seated in the headstrap. There should be no gaps between the pads and the headstrap.
  4. HTC Vive Cosmos Headstrap Hinge Replacement, Remove the audio cables: 手順 4、 3の画像 1 HTC Vive Cosmos Headstrap Hinge Replacement, Remove the audio cables: 手順 4、 3の画像 2 HTC Vive Cosmos Headstrap Hinge Replacement, Remove the audio cables: 手順 4、 3の画像 3
    • Carefully lift the audio connector cable out of its slot in the front of the headstrap.
  5. HTC Vive Cosmos Headstrap Hinge Replacement: 手順 5、 2の画像 1 HTC Vive Cosmos Headstrap Hinge Replacement: 手順 5、 2の画像 2
    • Carefully lift the audio interconnect cable out of its slot in the front of the headstrap.
  6. HTC Vive Cosmos Headstrap Hinge Replacement, Remove the headstrap: 手順 6、 1の画像 1
    • Use a T5 Torx drive to remove the ten 4.1 mm long screws securing the headstrap.
  7. HTC Vive Cosmos Headstrap Hinge Replacement: 手順 7、 2の画像 1 HTC Vive Cosmos Headstrap Hinge Replacement: 手順 7、 2の画像 2
    • Remove the headstrap.
  8. HTC Vive Cosmos Headstrap Hinge Replacement, Release the faceplate switch: 手順 8、 2の画像 1 HTC Vive Cosmos Headstrap Hinge Replacement, Release the faceplate switch: 手順 8、 2の画像 2
    • Use your finger to push the sliding faceplate release switch, sitting to the left of the lenses, toward the bottom of the Vive.
  9. HTC Vive Cosmos Headstrap Hinge Replacement, Remove the faceplate: 手順 9、 2の画像 1 HTC Vive Cosmos Headstrap Hinge Replacement, Remove the faceplate: 手順 9、 2の画像 2
    • While holding the switch in the bottom position, pull the faceplate straight up and away from the front of the Vive.
    • Remove the faceplate.
  10. HTC Vive Cosmos Headstrap Hinge Replacement, Remove the headstrap hinge: 手順 10、 1の画像 1
    • Use a T5 Torx driver to remove the three 4.1 mm long screws securing the headstrap hinge.
  11. HTC Vive Cosmos Headstrap Hinge Replacement: 手順 11、 1の画像 1
    • Use a T5 Torx driver to unscrew the captive screw securing the headstrap hinge.
    • There is a sticker covering this screw. Poke through it with your driver to access the screw.
  12. HTC Vive Cosmos Headstrap Hinge Replacement: 手順 12、 2の画像 1 HTC Vive Cosmos Headstrap Hinge Replacement: 手順 12、 2の画像 2
    • Slide the headstrap hinge out of its slot in the Vive and remove it.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Adam O'Camb
メンバー登録日: 04/11/15
197,115 ポイント
416のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 27
今までの合計 843
