メインコンテンツにスキップ
HTC Touch Pro CDMA Verizon Screen Replacement
必要な工具と部品
  1. HTC Touch Pro CDMA Verizon Screen Replacement, Battery: 手順 1、 1の画像 1
    • Remove the back cover (not pictured) to your phone.
  2. HTC Touch Pro CDMA Verizon Screen Replacement: 手順 2、 2の画像 1 HTC Touch Pro CDMA Verizon Screen Replacement: 手順 2、 2の画像 2
    • To remove the battery, place your thumb beneath the tab and begin to lift.
    • Pinching the battery, lift up at an angle from the bottom of the phone.
  3. HTC Touch Pro CDMA Verizon Screen Replacement, Basic Parts: 手順 3、 1の画像 1
    • Place the battery in a container off to the side. If you do this for every step beyond this point, you will keep better track of your parts and make reassembling the device far easier when you get around to it.
    • It might not be necessary, but we recommend using an anti-static bracelet or anti-static mat from this point on. Any charge on your finger tips may cause harm to the device.
  4. HTC Touch Pro CDMA Verizon Screen Replacement: 手順 4、 3の画像 1 HTC Touch Pro CDMA Verizon Screen Replacement: 手順 4、 3の画像 2 HTC Touch Pro CDMA Verizon Screen Replacement: 手順 4、 3の画像 3
    • Use a T6 screwdriver to remove the four screws on the rear plate of the HTC Touch Pro.
    • Place your screws in a bag labeled with where they came from, what screwdriver you used, and the order in which you removed them. For example, this bag would say "Rear casing. T6. #1."
  5. HTC Touch Pro CDMA Verizon Screen Replacement: 手順 5、 3の画像 1 HTC Touch Pro CDMA Verizon Screen Replacement: 手順 5、 3の画像 2 HTC Touch Pro CDMA Verizon Screen Replacement: 手順 5、 3の画像 3
    • Next, remove the casing that covers the camera and motherboard.
    • To do this, place your thumbnail in any of the grooves along either side and pry it open.
  6. HTC Touch Pro CDMA Verizon Screen Replacement: 手順 6、 2の画像 1 HTC Touch Pro CDMA Verizon Screen Replacement: 手順 6、 2の画像 2
    • Insert your spudger along the slit between the keyboard and the external casing. Pry open as shown.
    • Careful! The ribbon connecting the keyboard to the motherboard will still connect the two halves of the phone when you separate them. Be sure to take your time and move slowly to avoid damage to the cable.
  7. HTC Touch Pro CDMA Verizon Screen Replacement: 手順 7、 3の画像 1 HTC Touch Pro CDMA Verizon Screen Replacement: 手順 7、 3の画像 2 HTC Touch Pro CDMA Verizon Screen Replacement: 手順 7、 3の画像 3
    • Remove the keyboard ribbon from the motherboard. To do this, simply grasp the ribbon at its base and pry it up at an angle. The ribbon has a metal end that is easily removed from the motherboard.
  8. HTC Touch Pro CDMA Verizon Screen Replacement: 手順 8、 3の画像 1 HTC Touch Pro CDMA Verizon Screen Replacement: 手順 8、 3の画像 2 HTC Touch Pro CDMA Verizon Screen Replacement: 手順 8、 3の画像 3
    • Using a Phillips Head size 0 screwdriver, remove the 3 screws holding in the battery compartment.
    • Remove the ribbon covering the battery compartment by pinching it at the base and lifting.
  9. HTC Touch Pro CDMA Verizon Screen Replacement, Keyboard: 手順 9、 1の画像 1
    • Move the black slider over to the side without the keyboard ribbon. This is done as to allow the display ribbon to slide out later.
    • Using a PH 0 screwdriver, remove the 4 screws on the black slider.
  10. HTC Touch Pro CDMA Verizon Screen Replacement: 手順 10、 2の画像 1 HTC Touch Pro CDMA Verizon Screen Replacement: 手順 10、 2の画像 2
    • Pry the keyboard away from the screen. Open on the side containing the keyboard ribbon.
  11. HTC Touch Pro CDMA Verizon Screen Replacement, Screen: 手順 11、 2の画像 1 HTC Touch Pro CDMA Verizon Screen Replacement, Screen: 手順 11、 2の画像 2
    • Remove the four screws on the back of the screen assembly using the PH #0 screwdriver.
    • Move the silver slider across the phone so that you are able to pry the back off without damaging the display ribbon.
  12. HTC Touch Pro CDMA Verizon Screen Replacement: 手順 12、 2の画像 1 HTC Touch Pro CDMA Verizon Screen Replacement: 手順 12、 2の画像 2
    • Pry the rear of the screen assembly off from the side opposite to the display ribbon using the spudger
  13. HTC Touch Pro CDMA Verizon Screen Replacement: 手順 13、 3の画像 1 HTC Touch Pro CDMA Verizon Screen Replacement: 手順 13、 3の画像 2 HTC Touch Pro CDMA Verizon Screen Replacement: 手順 13、 3の画像 3
    • Remove the connected circuit board components behind the phone's navigation buttons.
    • Remove the four circuit board screws using the PH #0 screwdriver
  14. HTC Touch Pro CDMA Verizon Screen Replacement: 手順 14、 2の画像 1 HTC Touch Pro CDMA Verizon Screen Replacement: 手順 14、 2の画像 2
    • Push on the back of the board gently to remove the navigation buttons on the front.
    • Flip the phone to the front and remove the four screws holding the circuit board to the phone frame using the PH #0 screwdriver.
    • Replace the navigation buttons as necessary.
  15. HTC Touch Pro CDMA Verizon Screen Replacement: 手順 15、 2の画像 1 HTC Touch Pro CDMA Verizon Screen Replacement: 手順 15、 2の画像 2
    • Remove the two screws at the top of the screen using the PH #0 screwdriver.
    • Remove the beige piece after the screws have been removed as shown.
  16. HTC Touch Pro CDMA Verizon Screen Replacement: 手順 16、 2の画像 1 HTC Touch Pro CDMA Verizon Screen Replacement: 手順 16、 2の画像 2
    • Push gently on the back of the screen to release the glue holding it to the phone frame.
    • Peel the screen from the frame to completely separate the two components.
    • The glue between the screen and the phone frame is the only piece holding the two components together at this step.
終わりに
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Jack Bowen
メンバー登録日: 04/09/11
79 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 20-67, Walters Spring 2011 Cal Poly, Team 20-67, Walters Spring 2011人のメンバー
CPSU-WALTERS-S11S20G67
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 2,761
