メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HTC One S USB Port Replacement
必要な工具と部品
  1. HTC One S USB Port Replacement, iOpener Heating: 手順 1、 2の画像 1 HTC One S USB Port Replacement, iOpener Heating: 手順 1、 2の画像 2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. HTC One S USB Port Replacement: 手順 2、 1の画像 1
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. HTC One S USB Port Replacement: 手順 3、 1の画像 1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. HTC One S USB Port Replacement, Alternate iOpener heating method: 手順 4、 2の画像 1 HTC One S USB Port Replacement, Alternate iOpener heating method: 手順 4、 2の画像 2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. HTC One S USB Port Replacement, Rear Case: 手順 5、 1の画像 1
    • Handling it by the tag, place the heated iOpener across the bottom casing.
    • Let the iOpener sit for at least a minute to soften the adhesive beneath the casing.
  6. HTC One S USB Port Replacement: 手順 6、 3の画像 1 HTC One S USB Port Replacement: 手順 6、 3の画像 2 HTC One S USB Port Replacement: 手順 6、 3の画像 3
    • Gently place an opening pick in the corner of the gap between the bottom casing and rear case.
    • Slide the opening pick along the side of the casing, prying it away from the adhesive as you go.
  7. HTC One S USB Port Replacement: 手順 7、 1の画像 1
    • Use your fingers to pull the bottom casing off the rest of the phone.
  8. HTC One S USB Port Replacement: 手順 8、 2の画像 1 HTC One S USB Port Replacement: 手順 8、 2の画像 2
    • Starting at the groove near the headphone jack, use a plastic opening tool to lift the top casing.
  9. HTC One S USB Port Replacement: 手順 9、 1の画像 1
    • Use your fingers to pull the top casing off of the rest of the phone.
  10. HTC One S USB Port Replacement: 手順 10、 1の画像 1
    • Remove the following screws holding the rear case to the rest of the phone:
    • Two 3.15 mm Phillips #00 screws
    • One 4.15 Torx T5 screw
    • One 4 mm Torx T5 screw
  11. HTC One S USB Port Replacement: 手順 11、 3の画像 1 HTC One S USB Port Replacement: 手順 11、 3の画像 2 HTC One S USB Port Replacement: 手順 11、 3の画像 3
    • Place your fingers on either side of the phone and gently push up on the rear case.
    • It is important to start from the bottom of the phone because the rear case wraps around the front of the phone at the top which makes it impossible to start prying from there.
  12. HTC One S USB Port Replacement: 手順 12、 1の画像 1
    • Pull the rear case away from the rest of the phone with your hands.
  13. HTC One S USB Port Replacement, Battery: 手順 13、 2の画像 1 HTC One S USB Port Replacement, Battery: 手順 13、 2の画像 2
    • Using the pointed end of a spudger, lift the battery cable and release the connector.
  14. HTC One S USB Port Replacement: 手順 14、 2の画像 1 HTC One S USB Port Replacement: 手順 14、 2の画像 2
    • Switching to the flat end of the spudger, work your way underneath the battery and peel it away from the adhesive.
  15. HTC One S USB Port Replacement: 手順 15、 1の画像 1
    • Remove the battery from the phone.
  16. HTC One S USB Port Replacement, Motherboard: 手順 16、 1の画像 1
    • Remove the three 3.15mm Phillips #00 screws from the turquoise case.
  17. HTC One S USB Port Replacement: 手順 17、 2の画像 1 HTC One S USB Port Replacement: 手順 17、 2の画像 2
    • Using a plastic opening tool, lift the turquoise case from the end near the headphone jack.
  18. HTC One S USB Port Replacement: 手順 18、 1の画像 1
    • Remove the turquoise cover from the phone.
  19. HTC One S USB Port Replacement: 手順 19、 2の画像 1 HTC One S USB Port Replacement: 手順 19、 2の画像 2
    この手順で使用する道具:
    • A camera filter is now free to move, so remove it using tweezers.
  20. HTC One S USB Port Replacement: 手順 20、 3の画像 1 HTC One S USB Port Replacement: 手順 20、 3の画像 2 HTC One S USB Port Replacement: 手順 20、 3の画像 3
    • Use tweezers to lift the yellow polyimide tape that covers the ZIF connectors.
  21. HTC One S USB Port Replacement: 手順 21、 2の画像 1 HTC One S USB Port Replacement: 手順 21、 2の画像 2
    • Use the pointed end of a spudger to lift the white tab on the largest ZIF connector opposite the USB connector.
  22. HTC One S USB Port Replacement: 手順 22、 3の画像 1 HTC One S USB Port Replacement: 手順 22、 3の画像 2 HTC One S USB Port Replacement: 手順 22、 3の画像 3
    • Use the pointed edge of a spudger to work the ZIF cable out of its connector.
    • To do this, you may have to slowly work both sides until the whole cable is released.
  23. HTC One S USB Port Replacement: 手順 23、 1の画像 1
    • Repeat the procedure from steps 19 and 20 to remove the cables from the remaining ZIF connectors.
  24. HTC One S USB Port Replacement: 手順 24、 2の画像 1 HTC One S USB Port Replacement: 手順 24、 2の画像 2
    • Using the pointed end of the spudger, pop the antenna cable from its connector on the motherboard.
  25. HTC One S USB Port Replacement: 手順 25、 1の画像 1
    • Remove the 3.15 mm Phillips #00 screw from the motherboard.
  26. HTC One S USB Port Replacement: 手順 26、 2の画像 1 HTC One S USB Port Replacement: 手順 26、 2の画像 2
    • Remove the motherboard from the rest of the phone.
  27. HTC One S USB Port Replacement, USB Port: 手順 27、 2の画像 1 HTC One S USB Port Replacement, USB Port: 手順 27、 2の画像 2
    この手順で使用する道具:
    • Using tweezers, remove the adhesive tape around the USB port.
  28. HTC One S USB Port Replacement: 手順 28、 1の画像 1
    • Using a soldering iron set at 400 degrees Celsius (752 degrees Fahrenheit), heat the solder joints lateral to the USB port. Use a pair of tweezers to lift the port from the board.
    • Extreme caution should be taken when working with high-temperature equipment to reduce the chance of burns.
    • Care should be taken while desoldering the joints as the heat could melt the plastic casing on the port. It is strongly recommended that soldering surface-mounted components guide is referenced before proceeding.
終わりに
作成者
2人の作成者と共同で作成されました。
Adam Redmond
メンバー登録日: 05/16/17
535 ポイント
5のガイドは作成済み
チーム
IUPUI, Team S4-G3, Harley Spring 2017 IUPUI, Team S4-G3, Harley Spring 2017人のメンバー
IUPUI-HARLEY-S17S4G3
3 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 18
過去 30 日: 70
今までの合計 883
