メインコンテンツにスキップ
HTC One Remix Motherboard Replacement
必要な工具と部品
  1. HTC One Remix Motherboard Replacement, Motherboard: 手順 1、 1の画像 1
    • Use the sim eject tool to remove the SIM cards on either side of the phone.
  2. HTC One Remix Motherboard Replacement: 手順 2、 1の画像 1
    • Heat up the iOpener in the microwave for one minute. Place the iOpener on the top of the phone for three minutes.
    • iOpenerの使用方法
  3. HTC One Remix Motherboard Replacement: 手順 3、 1の画像 1
    • Once the top of the phone is warm, use a plastic spudger to pry the top left corner up.
    • The top is glued on so it may be difficult to get off.
  4. HTC One Remix Motherboard Replacement: 手順 4、 1の画像 1
    • Take out the small 3 mm screw that is on the top left side using a T5 bit.
  5. HTC One Remix Motherboard Replacement: 手順 5、 2の画像 1 HTC One Remix Motherboard Replacement: 手順 5、 2の画像 2
    • Use the plastic spudger to pry off the back cover. Place the tool in the SIM card insert and lift off the back cover with force. Continue to do this all around the phone.
    • Be careful to not break the wiring that is connected from the inside to the back of the phone.
    • The plastic spudger may not work. If this is the case, you may have to resort to using the metal prying tool. Please use with caution.
  6. HTC One Remix Motherboard Replacement: 手順 6、 2の画像 1 HTC One Remix Motherboard Replacement: 手順 6、 2の画像 2
    この手順で使用する道具:
    購入する
    • With tweezers, remove the small pieces of yellow tape that hold the phone in place.
    • Use the plastic prying tool to take off the three pieces of silver tape. They are located at the bottom right corner of the copper place.
    • Please note that the second photo is upside-down.
  7. HTC One Remix Motherboard Replacement: 手順 7、 3の画像 1 HTC One Remix Motherboard Replacement: 手順 7、 3の画像 2 HTC One Remix Motherboard Replacement: 手順 7、 3の画像 3
    • With the plastic spudger, disconnect the eight ZIF connectors. Do this by lifting the small white lines up and pulling the ribbon from it.
    • Use tweezers to carefully detach the eight ribbon cables from the connectors.
  8. HTC One Remix Motherboard Replacement: 手順 8、 1の画像 1
    • Remove the two 1 mm screws at the bottom right of the motherboard using a Phillips #00 screwdriver.
  9. HTC One Remix Motherboard Replacement: 手順 9、 2の画像 1 HTC One Remix Motherboard Replacement: 手順 9、 2の画像 2
    • Pull off one end of each of the five colored connecting cables from the motherboard.
    • Pull the black and red wire from the motherboard on the bottom left.
  10. HTC One Remix Motherboard Replacement: 手順 10、 1の画像 1
    • Take out the four 3 mm screws that are on each corner of the motherboard using a Torx 4 screwdriver.
    • Gently lift the motherboard out of the phone using the plastic spudger.
    • Watch the ribbon connectors when removing the motherboard as they may get in the way.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Marcos Loza
メンバー登録日: 04/10/18
936 ポイント
4のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 155
