このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
After removing the rubber stoppers on top, there should be six exposed screws. Remove these using the T6 screwdriver.
Next, use the spudger to loosen the case underneath the shiny metal edge. Go all the way around the phone until completely loosened.
After loosening the case, remove it.
この手順は未翻訳です。 翻訳を手伝う。
Remove the metal backing to the keyboard using Phillip 00 screwdriver to remove the 3 screws.
After the screws are removed, take off the back cover of the keyboard.
You can now peel off the keyboard, and replace it. After the new keyboard is in place, reassemble the device.
