メインコンテンツにスキップ
HTC EVO Design 4G Charging Port Replacement
必要な工具と部品
  1. HTC EVO Design 4G Charging Port Replacement, Screen: 手順 1、 1の画像 1
    この手順で使用する道具:
    • Tools: Phillips #000 Screwdriver, T4 Torx Screwdriver, Safety Pry Tool (Guitar pick), Tweezers
  2. HTC EVO Design 4G Charging Port Replacement, Removing Casing: 手順 2、 1の画像 1
    • Use fingers on either end of the button edges of the phone to pull back cover off. It should slide off.
  3. HTC EVO Design 4G Charging Port Replacement, Removing Battery: 手順 3、 2の画像 1 HTC EVO Design 4G Charging Port Replacement, Removing Battery: 手順 3、 2の画像 2
    • When open, pull on “Open” tab and it should rotate towards you
    • Grab the bottom edge of the battery and pull it toward you
  4. HTC EVO Design 4G Charging Port Replacement, Removing Casing: 手順 4、 2の画像 1 HTC EVO Design 4G Charging Port Replacement, Removing Casing: 手順 4、 2の画像 2
    • On the side of the top casing on the phone there should be a slot. Use your safety pry tool (guitar pick) pry around the perimeter of the casing to remove it
    • Info*: The adhesive tape that you may find will not be necessary for replacement later
  5. HTC EVO Design 4G Charging Port Replacement, Removing Screws: 手順 5、 2の画像 1 HTC EVO Design 4G Charging Port Replacement, Removing Screws: 手順 5、 2の画像 2
    • Remove the two Phillips screws to release the casing above the port
    • Remove the top and bottom pairs of Torx screws.
    • Remove the middle pair of two Phillips screws.
  6. HTC EVO Design 4G Charging Port Replacement, Removing Casing: 手順 6、 3の画像 1 HTC EVO Design 4G Charging Port Replacement, Removing Casing: 手順 6、 3の画像 2 HTC EVO Design 4G Charging Port Replacement, Removing Casing: 手順 6、 3の画像 3
    • To remove the remaining cover, lift the side port, which was previously uncovered, then lift the outer shell from the bottom of the phone and slide it forward
  7. HTC EVO Design 4G Charging Port Replacement, Removing Screws Continued: 手順 7、 2の画像 1 HTC EVO Design 4G Charging Port Replacement, Removing Screws Continued: 手順 7、 2の画像 2
    • Remove the two revealed screws on the outside (Torx = red, Phillips = orange), and then remove the two phillips on the bottom of the phone
  8. HTC EVO Design 4G Charging Port Replacement, Removing Rear Housing: 手順 8、 2の画像 1 HTC EVO Design 4G Charging Port Replacement, Removing Rear Housing: 手順 8、 2の画像 2
    • Remove the rear housing by prying around the edge with your Safety Pry Tool
  9. HTC EVO Design 4G Charging Port Replacement, Pull the Plug: 手順 9、 1の画像 1
    • Unplug the wire connecting the vibrator to the board with your tweezers
  10. HTC EVO Design 4G Charging Port Replacement, Like a Book: 手順 10、 1の画像 1
    • Unfold motherboard from the screen (open carefully like a book)
  11. HTC EVO Design 4G Charging Port Replacement, Flex Cables: 手順 11、 1の画像 1
    • Disconnect the two aluminum flex cables
  12. HTC EVO Design 4G Charging Port Replacement, Broken Bond: 手順 12、 1の画像 1
    • The flex cables should be the only binding and after being removed should leave you with the separate screen
  13. HTC EVO Design 4G Charging Port Replacement, Charging Port: 手順 13、 2の画像 1 HTC EVO Design 4G Charging Port Replacement, Charging Port: 手順 13、 2の画像 2
    この手順で使用する道具:
    Desoldering Pump
    $3.99
    • Use solder sucker to remove solder from the back of charging port
    • Use solder sucker to remove solder from the front of charging port
    • There are 2 soldering locations from the top view and 4 locations from the bottom view
    • Refer to the How To Solder and Desolder Connections guide if needed.
    • Solder sucker will be very hot
終わりに
作成者
3人の作成者と共同で作成されました。
Lilian Nguyen
メンバー登録日: 03/02/17
208 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S3-G2, Harley Spring 2017 IUPUI, Team S3-G2, Harley Spring 2017人のメンバー
IUPUI-HARLEY-S17S3G2
4 メンバー
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 508
