はじめに
Use this guide to replace the daughterboard on your Android HTC Desire 826.
If the charging port is loose or the phone is having trouble charging, the daughterboard may be damaged.
For safety purposes have the battery charged below 25% before dissasembling. If the battery is swollen this reduces risk of fire if the battery gets damaged during repair.
必要な工具と部品
Find a seam in the back of the device.
Insert the plastic spudger into the seam and pry off the back panel.
Use a T5 Torx screwdriver to remove the two 4.0 mm screws in the bottom corners of the device.
ある他の人がこのガイドを完成しました。
