はじめに
This guide provides clear, step-by-step instructions on how to safely remove and replace the battery in the HP iPAQ H3850.The HP iPAQ H3850 uses a rechargeable lithium-ion battery. Over time, the battery may lose its ability to hold a charge, making replacement necessary.
Common signs that your battery needs replacing include:
- Device fails to power on without being connected to a charger
- Rapid battery drain despite minimal use
- Battery does not charge to full capacity
- System warnings indicating battery issues
For more troubleshooting steps, visit the HP iPAQ H3850 Troubleshooting.
Safety
Swollen Batteries: If you notice a swollen or deformed battery, avoid puncturing or mishandling it, as this could pose a safety risk. What to Do With a Swollen Battery
Proper Disposal: Dispose of old batteries according to local electronic waste regulations—never discard batteries in regular household waste.
必要な工具と部品
Place the device on a flat surface with the screen facing down.
Use a screwdriver to remove four screws from the back cover of the device.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 の人々がこのガイドを完成させました。
3件のガイドコメント
Does anyone know where nowadays is it possible to get one of those batteries? I’ve been all over the internet and so far found zero… ?
in_sympathy - 返信 共有
HI @alexanderre! I have no idea if you're still looking for this battery or not, but if you are, post this question on the Answers forum. More eyes will see it there.
Amber Taus - 返信 共有
Hi @amber
Thanks for a hint, will do 🙏
in_sympathy - 返信 共有
