メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP ZBook 15 RAM Replacement
必要な工具と部品
  1. HP ZBook 15 RAM Replacement, Battery: 手順 1、 2の画像 1 HP ZBook 15 RAM Replacement, Battery: 手順 1、 2の画像 2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
    FixBotに聞いてみる
    コメントを追加
  2. HP ZBook 15 RAM Replacement, Back Cover: 手順 2、 1の画像 1
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
    FixBotに聞いてみる
    コメントを追加
  3. HP ZBook 15 RAM Replacement, Keyboard: 手順 3、 1の画像 1
    • Remove the two 16mm screws with a Phillips #0 screwdriver.
    • There are two sets of threads to get past. Once unscrewed from the first thread, lift the screw up until it hits the next set and begin unscrewing again.
    FixBotに聞いてみる
    コメントを追加
  4. HP ZBook 15 RAM Replacement: 手順 4、 3の画像 1 HP ZBook 15 RAM Replacement: 手順 4、 3の画像 2 HP ZBook 15 RAM Replacement: 手順 4、 3の画像 3
    • Do not try to pry the keyboard from the bottom. The keyboard is attached by clips on the left, top, and right side. Metal inserts on the bottom side lock the keyboard in place until they are slid up and out.
    • Be careful not to scratch or chip the computer when prying. If you have a plastic tool that is long enough to gain leverage, use that instead of a metal tool.
    • There are ribbons secured underneath so be careful not to pull the keyboard out too hard, breaking the connections to the ribbons.
    • Flip the laptop over so the keyboard is visible.
    • Insert the spudger under the left side of the keyboard.
    • Carefully raise the side of the keyboard and firmly pull the left corner of the keyboard until it pops up.
    • Run your fingers under the edges of the keyboard along the top edge of the keyboard, from the top left to the top right, to separate it from the remaining clips.
    • Carefully slide the keyboard up toward the screen and out of the case.
    FixBotに聞いてみる
    コメントを追加
  5. HP ZBook 15 RAM Replacement: 手順 5、 3の画像 1 HP ZBook 15 RAM Replacement: 手順 5、 3の画像 2 HP ZBook 15 RAM Replacement: 手順 5、 3の画像 3
    • Gently lift the two tabs on either side of the black ribbon with a spudger until the ribbon comes loose.
    • Disconnect the black ribbon by pulling the blue tab hanging off of it.
    • Repeat with the white ribbon.
    FixBotに聞いてみる
    コメントを追加
  6. HP ZBook 15 RAM Replacement, RAM: 手順 6、 2の画像 1 HP ZBook 15 RAM Replacement, RAM: 手順 6、 2の画像 2
    • Make sure the laptop is oriented bottom-up.
    • Pull the clips away from the RAM card and the module will pop out.
    • Lift the module out and repeat for the other RAM card.
    FixBotに聞いてみる
    コメントを追加
  7. HP ZBook 15 RAM Replacement: 手順 7、 1の画像 1
    • After removing the keyboard , flip the laptop over and remove the other two modules.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
4 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Grant Terris
メンバー登録日: 01/30/15
2,888 ポイント
12のガイドは作成済み
チーム
Cal Poly, Team 8-43, Amido Winter 2015 Cal Poly, Team 8-43, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S8G43
4 メンバー
19のガイドは作成済み
4件のガイドコメント
There are an additional 2x RAM slots underneath the keyboard on the one we received, so don’t be surprised if you open the bottom and find no RAM in the usual spot.
Mars - 返信 共有
There is no cradle or however you name it under the keyboard, pls advise.
Andreas Hollerer - 返信 共有
Step 4 should be “Remove the keyboard” and the present step 4 therby becomes step 5.
Pete Fielder - 返信 共有
Note that this guide applies to quad-core models (Core i7-4800MQ and up). If you have a dual-core model (Core i7-4600M or less), you don’t have the two extra RAM slots under the keyboard, you only have the two slots from under the service door/cover.
So yeah, save yourself the hastle of removing the keyboard, and keep this in mind if you’re planning to go above 16GB of RAM.
Luis Alejandro Araúz - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 99
今までの合計 22,888
