メインコンテンツにスキップ
HP Z2 Mini G3 Real-Time Clock Battery Replacement
  1. HP Z2 Mini G3 Real-Time Clock Battery Replacement, Access Panel: 手順 1、 1の画像 1
    • Turn the device so the back-side of the device is facing you.
    • Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm yourself.
    • Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
  2. HP Z2 Mini G3 Real-Time Clock Battery Replacement: 手順 2、 2の画像 1 HP Z2 Mini G3 Real-Time Clock Battery Replacement: 手順 2、 2の画像 2
    • Slide and hold the latch in the direction of the engraved arrow (to the right).
  3. HP Z2 Mini G3 Real-Time Clock Battery Replacement: 手順 3、 2の画像 1 HP Z2 Mini G3 Real-Time Clock Battery Replacement: 手順 3、 2の画像 2
    • While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
  4. HP Z2 Mini G3 Real-Time Clock Battery Replacement, Real-Time Clock Battery: 手順 4、 1の画像 1
    • Rotate the device so the back-side is facing you and locate the RTC battery.
    • You may have to swing the CPU Fan and GPU Fan upwards to fully access the Real-Time Clock (RTC) Battery.
  5. HP Z2 Mini G3 Real-Time Clock Battery Replacement: 手順 5、 1の画像 1
    • Press the battery down and away to free it of the latches.
    • Use your hand to grab and lift the battery out of the socket.
終わりに
作成者
2人の作成者と共同で作成されました。
Christian Ogburn
メンバー登録日: 01/14/20
475 ポイント
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 21
過去 30 日: 118
今までの合計 2,084
