はじめに
This guide instructs you on how to remove and replace the heatsink and fan assembly in a HP Spectre x360 13t-4000. Replacement of the heatsink may be necessary if the laptop is overheating.
必要な工具と部品
Turn off and unplug the laptop.
Flip over the laptop so that the bottom backplate is exposed.
Use a Phillips #0 Screwdriver to remove the four circled 3 mm screws.
Use the same screwdriver to remove the circled 4 mm screw.
もう少しです!
終わりに
