メインコンテンツにスキップ
HP Photosmart Premium e-All-in-One C310a Touch Pad Replacement
必要な工具と部品
  1. HP Photosmart Premium e-All-in-One C310a Touch Pad Replacement, Remove the Mounting Screws: 手順 1、 2の画像 1 HP Photosmart Premium e-All-in-One C310a Touch Pad Replacement, Remove the Mounting Screws: 手順 1、 2の画像 2
    • Tilt the touchscreen as far forward as possible.
    • Remove the two (2) 15mm T-10 Torx screws from behind the screen.
  2. HP Photosmart Premium e-All-in-One C310a Touch Pad Replacement, Separate the Touchpad from the Printer: 手順 2、 1の画像 1
    • Once the screws are removed, apply a steady upward force on the front bottom corners of the screen until it pops loose.
    • Be careful to not move the screen too far from the printer before disconnecting it. You may damage the connections within the printer if you do.
  3. HP Photosmart Premium e-All-in-One C310a Touch Pad Replacement, Disconnect the Ribbon Cables: 手順 3、 2の画像 1 HP Photosmart Premium e-All-in-One C310a Touch Pad Replacement, Disconnect the Ribbon Cables: 手順 3、 2の画像 2
    • Before removing the ribbon cable, flip the black bar up to unlock the cable. Grab the blue area of the cable near the connector and pull straight out of the socket.
    • Pull this plug straight out of the socket slowly.
    • Be careful when pulling out these ribbon cables. If you pull too hard or don't unlock the cable, you can damage the connection.
  4. HP Photosmart Premium e-All-in-One C310a Touch Pad Replacement, Remove the Touchpad: 手順 4、 1の画像 1
    • Once the ribbon cables have been removed, your screen should be free of the printer.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Andrew Schaub
メンバー登録日: 10/23/14
569 ポイント
5のガイドは作成済み
チーム
Michigan Tech, Team 1-4, Lauer Fall 2014 Michigan Tech, Team 1-4, Lauer Fall 2014人のメンバー
MTU-LAUER-F14S1G4
3 メンバー
5のガイドは作成済み
コメント 1 件
It would be useful to know where this skill leads. Can one open up the touchpad and address the issue that makes it unresponsive? Where can one get a replacement screen? The HP site has all kinds of steps to correct a partially unresponsive keypad that assume the problem is software or firmware based. Maybe, but my experience was that HP's suggestions do not fix what is probably a hardware problem. So, it's great that one can get into the guts of the keypad, but given that HP isn't forthcoming with replacement parts, suggesting where to get them, or what to try to fix the faulty pad would be very useful info. Just saying!
Terry O'Brien - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 14
今までの合計 1,014
