メインコンテンツにスキップ
HP Pavilion x360 14m-ba011dx Touchpad Replacement
必要な工具と部品
  1. HP Pavilion x360 14m-ba011dx Touchpad Replacement, Touchpad: 手順 1、 2の画像 1 HP Pavilion x360 14m-ba011dx Touchpad Replacement, Touchpad: 手順 1、 2の画像 2
    • Remove the top left and right rubber pads closest to the hinge of the screen using a plastic spudger to locate the screws underneath. ​
    • Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:
    • Remove two 7.5 mm screws.
    • Remove three 5 mm screws.
    • Remove one 6.5 mm screw.
  2. HP Pavilion x360 14m-ba011dx Touchpad Replacement: 手順 2、 1の画像 1
    • Push into the two screw holes located under the rubber pads with the screwdriver to pop the keyboard out slightly.
    • Do this with the screen open so that you do not damage the screen.
    • Do not remove the keyboard all the way.
  3. HP Pavilion x360 14m-ba011dx Touchpad Replacement: 手順 3、 2の画像 1 HP Pavilion x360 14m-ba011dx Touchpad Replacement: 手順 3、 2の画像 2
    • Separate the keyboard from the rest of the device using a metal spudger around edges.
    • Pull up gently until you can see the cables attaching the keyboard to the motherboard.
    • Flip the small white clasps that hold the three cables to the motherboard open and unplug the cables.
  4. HP Pavilion x360 14m-ba011dx Touchpad Replacement: 手順 4、 2の画像 1 HP Pavilion x360 14m-ba011dx Touchpad Replacement: 手順 4、 2の画像 2
    • Flip the now removed keyboard over to expose the bottom side.
    • Unclasp the cable that connects the touchpad to the keyboard.
    • You can remove this cable the same way you removed the previous cables.
    • Remove the six 2.3 mm screws that attach the touch pad using a Phillips #00 Screwdriver.
  5. HP Pavilion x360 14m-ba011dx Touchpad Replacement: 手順 5、 2の画像 1 HP Pavilion x360 14m-ba011dx Touchpad Replacement: 手順 5、 2の画像 2
    • Pull off the metal piece holding the touchpad in place.
    • Remove the touchpad from the device.
終わりに
作成者
2人の作成者と共同で作成されました。
Katie Pruis
メンバー登録日: 01/16/20
799 ポイント
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 15
今までの合計 1,555
