はじめに
Before using this guide, make sure to review the troubleshooting page for the HP Pavilion x360 14m-ba011dx. The speakers may not actually need to be replaced depending on the problem, which is why it is good to trouble shoot first.
With this guide, users will be able to remove and replace the speakers on the HP Pavilion x360 14m-ba011dx laptop. The model number for this device is 1KT47UA. Removal of the speakers will be needed if they are not producing sound or the sound is inconsistent.
必要な工具と部品
Remove the top left and right rubber pads closest to the hinge of screen using a plastic spudger to locate the screws underneath.
Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:
Remove two 7.5 mm screws.
Remove three 5 mm screws.
Remove one 6.5 mm screw.
