メインコンテンツにスキップ
HP Pavilion x360 11m-ad013dx Battery Replacement
必要な工具と部品
  1. HP Pavilion x360 11m-ad013dx Battery Replacement, Keyboard: 手順 1、 1の画像 1
    • Lay the HP Pavilion top-down with the front edge facing towards you.
  2. HP Pavilion x360 11m-ad013dx Battery Replacement: 手順 2、 1の画像 1
    • Remove the three 4.8mm Phillips #0 screws from the front side.
  3. HP Pavilion x360 11m-ad013dx Battery Replacement: 手順 3、 2の画像 1 HP Pavilion x360 11m-ad013dx Battery Replacement: 手順 3、 2の画像 2
    • Using a plastic spudger, remove the grey silicon strip closest to the back-side.
  4. HP Pavilion x360 11m-ad013dx Battery Replacement: 手順 4、 1の画像 1
    • Remove the three 5.7mm Phillips #1 screws.
  5. HP Pavilion x360 11m-ad013dx Battery Replacement: 手順 5、 2の画像 1 HP Pavilion x360 11m-ad013dx Battery Replacement: 手順 5、 2の画像 2
    • Open the HP Pavilion so that the screen is showing. Then tilt it down so that the screen is on its back, facing up.
    • Using a spudger, pry off the black keyboard panel.
    • This step requires force to unclasp the latches keeping the keyboard in place.
  6. HP Pavilion x360 11m-ad013dx Battery Replacement: 手順 6、 2の画像 1 HP Pavilion x360 11m-ad013dx Battery Replacement: 手順 6、 2の画像 2
    • Using your fingernail, disconnect the zero insertion force (ZIF) keyboard connector cable by flipping up the small locking flap.
    • You may disconnect the other end of the cable, for ease of access to other parts. Keep in mind that the end labeled MB connects to the motherboard.
  7. HP Pavilion x360 11m-ad013dx Battery Replacement: 手順 7、 2の画像 1 HP Pavilion x360 11m-ad013dx Battery Replacement: 手順 7、 2の画像 2
    • Using your fingernail, disconnect the zero insertion force (ZIF) connector for the touch pad cable by flipping up the small locking flap.
  8. HP Pavilion x360 11m-ad013dx Battery Replacement: 手順 8、 1の画像 1
    • Remove the keyboard.
  9. HP Pavilion x360 11m-ad013dx Battery Replacement, Battery: 手順 9、 1の画像 1
    • Remove the five 4.6mm Phillips #1 screws located around the battery.
  10. HP Pavilion x360 11m-ad013dx Battery Replacement: 手順 10、 2の画像 1 HP Pavilion x360 11m-ad013dx Battery Replacement: 手順 10、 2の画像 2
    • Using a spudger for assistance, lift up the right edge of the battery.
    • Remove the battery.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Hank Ferguson
メンバー登録日: 01/13/20
590 ポイント
4のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 38
今までの合計 1,398
