メインコンテンツにスキップ
HP Pavilion Sleekbook 15-b142dx Keyboard Replacement
必要な工具と部品
  1. HP Pavilion Sleekbook 15-b142dx Keyboard Replacement, Removing Keyboard: 手順 1、 3の画像 1 HP Pavilion Sleekbook 15-b142dx Keyboard Replacement, Removing Keyboard: 手順 1、 3の画像 2 HP Pavilion Sleekbook 15-b142dx Keyboard Replacement, Removing Keyboard: 手順 1、 3の画像 3
    • Open the laptop and locate the keyboard. Identify the borders of the keyboard.
    • Taking plastic opening tools in hand, carefully and gently pry open the outer perimeter of the keyboard.
    Wrong, you can't just remove the keyboard, you have to remove the 2 bolts labeled keyboard on the bottom or you are going to have a bad time.
    dloeper2391 - 返信
    Yes, as dloeper noted, the two screws on the bottom with the keyboard icons must be removed prior to this step. Might as well remove all the screws from the bottom, they all need to be removed (10 total, all the same size).
    maccentric - 返信
  2. HP Pavilion Sleekbook 15-b142dx Keyboard Replacement, Replacing Keyboard: 手順 2、 1の画像 1
    • Once part of the keyboard has popped up, continue to lift the keyboard until it is removed.
    Need to detach the two ribbon cables.
    Mat Kramer - 返信
    how do you reattach the ribbon cables?
    bhdxxx1984 - 返信
    I only had to remove 1 cable for the keyboard, the wide one. It is removed, and reattached, by flipping up the brown part of the socket. It was a little stiff on mine; I used 2 fingernails on either end of the socket to raise the flap up.
    maccentric -
終わりに
8 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jonathan
メンバー登録日: 01/13/15
758 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 3-3, Hickman Winter 2015 USF Tampa, Team 3-3, Hickman Winter 2015人のメンバー
USFT-HICKMAN-W15S3G3
4 メンバー
5のガイドは作成済み
2 Guide Comments
And how I remove the bezel?
Lorenzo Ricci - 返信
Where do I get the replacement keyboard for this?
I have an HP Pavilion Sleekbook 15-b012ee and I feel that the same keyboard would work
Author, please share the link
Tommy Vercaty - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 26
今までの合計 3,318
