はじめに
Use this guide to replace or upgrade the RAM in your HP Pavilion 15 Laptop PC.
Note: This procedure was written using a model 15-eg2015od HP 15 Pavilion Laptop PC, but is fully compatible with any HP 15 Pavilion Laptop PC whose model number starts with 15-eg or 15-eh.
This laptop has two RAM slots that support DDR4 SO-DIMM memory modules.
必要な工具と部品
Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
Peel up the end of the foot with your fingers just until the hidden screw underneath is exposed—you don't need to fully remove the foot.
Peel up the other ends of the feet to expose the three remaining screws.
Press down firmly on the ends of the feet to secure them into their recesses.
If the foot adhesive doesn't remain tacky enough to readhere, you can use double-sided tape such as Tesa Tape.
Use a Phillips screwdriver to remove the six screws securing the back cover:
Four larger 6.6 mm-long black screws
Two smaller 4.8 mm-long silver screws
Insert the flat end of a spudger between the top edge of the back cover and frame, just to the left of the right hinge.
Pry up with the spudger to release the clips securing the top right corner of the back cover.
Use a Phillips screwdriver to remove the six 3.9 mm-long screws securing the battery.
Gently lift the upper edge of the battery to disconnect its socket from the motherboard.
Remove the battery.
Your laptop has two memory slots, each with a pair of metal arms that secure a stick of RAM.
Simultaneously push out the metal arms on each side of a stick of RAM until they disengage and the stick pops up at a slight angle.
Pull the stick of RAM out of its socket to remove it.
Repeat for a second stick of RAM.
ある他の人がこのガイドを完成しました。
コメント 1 件
hello,
This is a very useful document with great pics & steps to follow for customers who are looking to upgrade their RAM. Thank you for creating this document. I would like to know if this content is available in English only?
And, if its available in other languages, can you please let me know what languages are offered?
Thanks & Regards,
Vasundhara
Vasundhara - 返信
