メインコンテンツにスキップ
HP Pavilion 15-cd040wm Screen Replacement
必要な工具と部品
  1. HP Pavilion 15-cd040wm Screen Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: 手順 1、 2の画像 1 HP Pavilion 15-cd040wm Screen Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: 手順 1、 2の画像 2
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
  2. HP Pavilion 15-cd040wm Screen Replacement: 手順 2、 2の画像 1 HP Pavilion 15-cd040wm Screen Replacement: 手順 2、 2の画像 2
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
  3. HP Pavilion 15-cd040wm Screen Replacement: 手順 3、 3の画像 1 HP Pavilion 15-cd040wm Screen Replacement: 手順 3、 3の画像 2 HP Pavilion 15-cd040wm Screen Replacement: 手順 3、 3の画像 3
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
  4. HP Pavilion 15-cd040wm Screen Replacement, Battery: 手順 4、 2の画像 1 HP Pavilion 15-cd040wm Screen Replacement, Battery: 手順 4、 2の画像 2
    • 2x 5mm Philips screws
    • 2x 3mm Philips screws
  5. HP Pavilion 15-cd040wm Screen Replacement: 手順 5、 2の画像 1 HP Pavilion 15-cd040wm Screen Replacement: 手順 5、 2の画像 2
    • Gently pull up on the battery and tilt it away from the rest of the laptop chassis.
    • Pull out the battery at an angle and lift it out of the laptop.
  6. HP Pavilion 15-cd040wm Screen Replacement, Screen: 手順 6、 3の画像 1 HP Pavilion 15-cd040wm Screen Replacement, Screen: 手順 6、 3の画像 2 HP Pavilion 15-cd040wm Screen Replacement, Screen: 手順 6、 3の画像 3
    • Remove the four 6.0 mm screws from the hinges using a size Phillips #0 screwdriver.
    • Use the iFixit opening tool to lift both of the hinges.
  7. HP Pavilion 15-cd040wm Screen Replacement: 手順 7、 3の画像 1 HP Pavilion 15-cd040wm Screen Replacement: 手順 7、 3の画像 2 HP Pavilion 15-cd040wm Screen Replacement: 手順 7、 3の画像 3
    • Using the spudger or opening tool, remove the ribbon that connects to the screen.
    • Gently pull the ribbon out of the port after using the spudger to lift the supporter up.
    • Carefully remove the two antenna wires that connect to the screen as well. Do this by gently pulling them free from their connectors at the wifi card.
  8. HP Pavilion 15-cd040wm Screen Replacement: 手順 8、 1の画像 1
    • Once these steps are completed, you may lift the display assembly free from the rest of the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Zachary Simao
メンバー登録日: 03/08/19
405 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G1, Botvin Fall 2019 UMass Dartmouth, Team S1-G1, Botvin Fall 2019人のメンバー
UMASSD-BOTVIN-F19S1G1
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 20
今までの合計 767
