メインコンテンツにスキップ
HP Pavilion 15-cd040wm Hard Drive Replacement
必要な工具と部品
  1. HP Pavilion 15-cd040wm Hard Drive Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: 手順 1、 2の画像 1 HP Pavilion 15-cd040wm Hard Drive Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: 手順 1、 2の画像 2
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
  2. HP Pavilion 15-cd040wm Hard Drive Replacement: 手順 2、 2の画像 1 HP Pavilion 15-cd040wm Hard Drive Replacement: 手順 2、 2の画像 2
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
  3. HP Pavilion 15-cd040wm Hard Drive Replacement: 手順 3、 3の画像 1 HP Pavilion 15-cd040wm Hard Drive Replacement: 手順 3、 3の画像 2 HP Pavilion 15-cd040wm Hard Drive Replacement: 手順 3、 3の画像 3
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
  4. HP Pavilion 15-cd040wm Hard Drive Replacement, Battery: 手順 4、 2の画像 1 HP Pavilion 15-cd040wm Hard Drive Replacement, Battery: 手順 4、 2の画像 2
    • 2x 5mm Philips screws
    • 2x 3mm Philips screws
  5. HP Pavilion 15-cd040wm Hard Drive Replacement: 手順 5、 2の画像 1 HP Pavilion 15-cd040wm Hard Drive Replacement: 手順 5、 2の画像 2
    • Gently pull up on the battery and tilt it away from the rest of the laptop chassis.
    • Pull out the battery at an angle and lift it out of the laptop.
  6. HP Pavilion 15-cd040wm Hard Drive Replacement, Hard Drive: 手順 6、 2の画像 1 HP Pavilion 15-cd040wm Hard Drive Replacement, Hard Drive: 手順 6、 2の画像 2
    • Using a spudger or the opening tool, lift the end closest to the battery until you can hold the hard drive with your hands.
  7. HP Pavilion 15-cd040wm Hard Drive Replacement: 手順 7、 2の画像 1 HP Pavilion 15-cd040wm Hard Drive Replacement: 手順 7、 2の画像 2
    • Carefully remove the connector ribbon cable from the elevated end of the hard drive, then remove the hard drive.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Brian Cornet
メンバー登録日: 10/21/19
316 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G1, Botvin Fall 2019 UMass Dartmouth, Team S1-G1, Botvin Fall 2019人のメンバー
UMASSD-BOTVIN-F19S1G1
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 28
今までの合計 1,984
