メインコンテンツにスキップ
HP Pavilion 15-bk020wm Touchscreen Replacement
必要な工具と部品
  1. HP Pavilion 15-bk020wm Touchscreen Replacement, Keyboard Cover: 手順 1、 2の画像 1 HP Pavilion 15-bk020wm Touchscreen Replacement, Keyboard Cover: 手順 1、 2の画像 2
    • Before you begin, turn the laptop off and unplug it from the power source.
    • Remove the 4 computer feet. (Our device didn't have these; they can be taken off with a plastic spudger.)
    • Remove the two screw cover strips.
    • Remove the two screw cover plugs.
    • Unscrew all 12 screws (size: Phillips M2.5×7.0 ) from the bottom of the computer.
  2. HP Pavilion 15-bk020wm Touchscreen Replacement: 手順 2、 3の画像 1 HP Pavilion 15-bk020wm Touchscreen Replacement: 手順 2、 3の画像 2 HP Pavilion 15-bk020wm Touchscreen Replacement: 手順 2、 3の画像 3
    • Turn the computer over to the front.
    • Open the laptop.
    • Use a plastic pry tool to pry up the keyboard cover near the hinge on both the right and left side, and work your way towards the touchpad.
  3. HP Pavilion 15-bk020wm Touchscreen Replacement: 手順 3、 1の画像 1
    • Tilt the keyboard cover up slightly.
    • Do not fully remove the keyboard, as it is still attached to the laptop by some cables.
  4. HP Pavilion 15-bk020wm Touchscreen Replacement, Battery: 手順 4、 2の画像 1 HP Pavilion 15-bk020wm Touchscreen Replacement, Battery: 手順 4、 2の画像 2
    • Detach the blue ZIF cable from the bottom of the laptop.
    • Use a plastic opening tool to flip up the two ZIF cables connecting the battery to the motherboard.
  5. HP Pavilion 15-bk020wm Touchscreen Replacement: 手順 5、 1の画像 1
    • Remove the four Phillips M2.5x4.4 screws using the Phillips 00 located along the perimeter of the battery.
  6. HP Pavilion 15-bk020wm Touchscreen Replacement: 手順 6、 1の画像 1
    • Lift the damaged battery from the laptop.
    • Insert the new battery.
  7. HP Pavilion 15-bk020wm Touchscreen Replacement, Touchscreen: 手順 7、 2の画像 1 HP Pavilion 15-bk020wm Touchscreen Replacement, Touchscreen: 手順 7、 2の画像 2
    • Detach the two cables from the motherboard.
  8. HP Pavilion 15-bk020wm Touchscreen Replacement: 手順 8、 1の画像 1
    • Unscrew all ten screws (M2.5x4.4) using the Phillips 00 screwdriver from the motherboard. Be sure to unscrew the fan as well.
    • Lift the motherboard with the fan.
  9. HP Pavilion 15-bk020wm Touchscreen Replacement: 手順 9、 2の画像 1 HP Pavilion 15-bk020wm Touchscreen Replacement: 手順 9、 2の画像 2
    • Unscrew the screen from the laptop body using Phillips 00. Screw size: M2.5x4.4
  10. HP Pavilion 15-bk020wm Touchscreen Replacement: 手順 10、 1の画像 1
    • Lift the touchscreen hinges using the plastic opening tool to detach the screen.
    • Obtain the new touchscreen to connect to your device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Meshayla Block
メンバー登録日: 06/28/17
437 ポイント
3のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 7
過去 30 日: 37
今までの合計 5,478
