メインコンテンツにスキップ
HP Pavilion 15-ba003ds Thermal Paste Replacement
必要な工具と部品
  1. HP Pavilion 15-ba003ds Thermal Paste Replacement, Battery: 手順 1、 2の画像 1 HP Pavilion 15-ba003ds Thermal Paste Replacement, Battery: 手順 1、 2の画像 2
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Thermal Paste Replacement, Disc Drive: 手順 2、 1の画像 1
    • Remove the two rubber feet next to the battery.
  3. HP Pavilion 15-ba003ds Thermal Paste Replacement: 手順 3、 2の画像 1 HP Pavilion 15-ba003ds Thermal Paste Replacement: 手順 3、 2の画像 2
    • There are twelve 8mm screws in total that need to be unscrewed
    • Using a Phillips #00 screwdriver, unscrew them all including the two screws found underneath the rubber feet.
  4. HP Pavilion 15-ba003ds Thermal Paste Replacement: 手順 4、 2の画像 1 HP Pavilion 15-ba003ds Thermal Paste Replacement: 手順 4、 2の画像 2
    • Once all twelve screws are removed the disc drive can now be gently pulled out by hand.
  5. HP Pavilion 15-ba003ds Thermal Paste Replacement, Backplate: 手順 5、 3の画像 1 HP Pavilion 15-ba003ds Thermal Paste Replacement, Backplate: 手順 5、 3の画像 2 HP Pavilion 15-ba003ds Thermal Paste Replacement, Backplate: 手順 5、 3の画像 3
    • Use a Jimmy to pry off the black backplate.
  6. HP Pavilion 15-ba003ds Thermal Paste Replacement, Thermal Paste: 手順 6、 2の画像 1 HP Pavilion 15-ba003ds Thermal Paste Replacement, Thermal Paste: 手順 6、 2の画像 2
    • Remove four 3mm Phillips #00 screws holding the CPU heatsink in place.
  7. HP Pavilion 15-ba003ds Thermal Paste Replacement: 手順 7、 3の画像 1 HP Pavilion 15-ba003ds Thermal Paste Replacement: 手順 7、 3の画像 2 HP Pavilion 15-ba003ds Thermal Paste Replacement: 手順 7、 3の画像 3
    • Gently wiggle and remove CPU heatsink.
    • Do not attempt to pull the heatsink away without having wiggled it, as it may cause damage to your motherboard.
    • Wiggle while holding the heatink on top of the CPU, not the fan housing.
  8. HP Pavilion 15-ba003ds Thermal Paste Replacement: 手順 8、 2の画像 1 HP Pavilion 15-ba003ds Thermal Paste Replacement: 手順 8、 2の画像 2
    • Generously apply the 99% isopropyl alcohol to your microfiber cloth.
    • Make sure that the thermal paste is completely wiped away and that the processor is dry
    • Apply a small pea sized amount of thermal paste to the processor.
    • Ensure that when you’re wiping away the old thermal paste that none of it falls onto the motherboard beneath it.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Joseph Chia
メンバー登録日: 01/14/20
355 ポイント
3のガイドは作成済み
チーム
York University, Team S1-G9, Woodhouse Winter 2020 York University, Team S1-G9, Woodhouse Winter 2020人のメンバー
YORK-WOODHOUSE-W20S1G9
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 29
過去 30 日: 62
今までの合計 2,619
