メインコンテンツにスキップ
HP EliteBook x360 830 G7 Touchpad Removal
必要な工具と部品
  1. HP EliteBook x360 830 G7 Touchpad Removal, Remove the backplate: 手順 1、 3の画像 1 HP EliteBook x360 830 G7 Touchpad Removal, Remove the backplate: 手順 1、 3の画像 2 HP EliteBook x360 830 G7 Touchpad Removal, Remove the backplate: 手順 1、 3の画像 3
    • Turn the computer over so that the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7 Touchpad Removal, Disconnect the bundled cable connector: 手順 2、 1の画像 1
    • Use a nylon spudger to gently disconnect the battery's bundled cable connector from the motherboard.
    • This bundled cable connector has a tab on each side. Insert the spudger between these tabs and the motherboard's battery connector port and gently push the battery connector out and away from the connector.
  3. HP EliteBook x360 830 G7 Touchpad Removal, Peel the copper foil tape: 手順 3、 2の画像 1 HP EliteBook x360 830 G7 Touchpad Removal, Peel the copper foil tape: 手順 3、 2の画像 2
    • Peel back both sides of the copper foil tape connected to the battery.
  4. HP EliteBook x360 830 G7 Touchpad Removal, Remove the screws: 手順 4、 2の画像 1 HP EliteBook x360 830 G7 Touchpad Removal, Remove the screws: 手順 4、 2の画像 2
    • Use a JIS #1 screwdriver to remove the four 4 mm screws that secure the battery.
  5. HP EliteBook x360 830 G7 Touchpad Removal, Remove the battery: 手順 5、 3の画像 1 HP EliteBook x360 830 G7 Touchpad Removal, Remove the battery: 手順 5、 3の画像 2 HP EliteBook x360 830 G7 Touchpad Removal, Remove the battery: 手順 5、 3の画像 3
    • Remove the battery from the laptop.
  6. HP EliteBook x360 830 G7 Touchpad Removal, Touchpad: 手順 6、 2の画像 1 HP EliteBook x360 830 G7 Touchpad Removal, Touchpad: 手順 6、 2の画像 2
    • Use a JIS #1 screwdriver to remove the six 2 mm screws holding the touchpad in place.
  7. HP EliteBook x360 830 G7 Touchpad Removal: 手順 7、 2の画像 1 HP EliteBook x360 830 G7 Touchpad Removal: 手順 7、 2の画像 2
    • Use a spudger or a clean fingernail to flip up the locking flap on the motherboard.
    • Use the widest tool possible to avoid damaging the delicate hinge pins.
    • Use tweezers or your fingers to gently pull the cable out of its socket by the tab.
    • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
  8. HP EliteBook x360 830 G7 Touchpad Removal: 手順 8、 2の画像 1 HP EliteBook x360 830 G7 Touchpad Removal: 手順 8、 2の画像 2
    • Use an opening tool or spudger to lift the metal bracket with the touchpad off of the laptop.
    • Remove the old touchpad.
終わりに
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
作成者
1人の作成者と共同作成されました。
Alec Aviles
メンバー登録日: 02/08/24
97 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 1-2, Coppersmith Spring 2024 University of North Texas, Team 1-2, Coppersmith Spring 2024人のメンバー
UNT-COPPERSMITH-S24S1G2
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 22
今までの合計 161
