メインコンテンツにスキップ
HP EliteBook x360 830 G6 Heatsink Replacement
必要な工具と部品
  1. HP EliteBook x360 830 G6 Heatsink Replacement, Unfasten the back cover: 手順 1、 1の画像 1
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 Heatsink Replacement, Release the clips: 手順 2、 2の画像 1 HP EliteBook x360 830 G6 Heatsink Replacement, Release the clips: 手順 2、 2の画像 2
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 Heatsink Replacement, Release the remaining clips: 手順 3、 2の画像 1 HP EliteBook x360 830 G6 Heatsink Replacement, Release the remaining clips: 手順 3、 2の画像 2
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 Heatsink Replacement, Remove the back cover: 手順 4、 3の画像 1 HP EliteBook x360 830 G6 Heatsink Replacement, Remove the back cover: 手順 4、 3の画像 2 HP EliteBook x360 830 G6 Heatsink Replacement, Remove the back cover: 手順 4、 3の画像 3
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
  5. HP EliteBook x360 830 G6 Heatsink Replacement, Disconnect the battery: 手順 5、 3の画像 1 HP EliteBook x360 830 G6 Heatsink Replacement, Disconnect the battery: 手順 5、 3の画像 2 HP EliteBook x360 830 G6 Heatsink Replacement, Disconnect the battery: 手順 5、 3の画像 3
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternate sides to "walk" the connector out.
  6. HP EliteBook x360 830 G6 Heatsink Replacement, Heatsink: 手順 6、 1の画像 1
    • Use a Phillips #0 screwdriver to remove each of the four 3 mm screws at each corner of the heatsink.
  7. HP EliteBook x360 830 G6 Heatsink Replacement: 手順 7、 3の画像 1 HP EliteBook x360 830 G6 Heatsink Replacement: 手順 7、 3の画像 2 HP EliteBook x360 830 G6 Heatsink Replacement: 手順 7、 3の画像 3
    • Gently pull the heatsink off of the motherboard.
    • Be sure to clean the old thermal paste and apply new thermal paste before replacing the heatsink.
    • Tighten the replacement heatsink screws in an "X" pattern.
終わりに
作成者
2人の作成者と共同で作成されました。
Brody Reder
メンバー登録日: 04/02/24
301 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 3-3, Harley Spring 2024 IUPUI, Team 3-3, Harley Spring 2024人のメンバー
IUPUI-HARLEY-S24S3G3
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 11
今までの合計 35
