メインコンテンツにスキップ
HP EliteBook x360 830 G6 Cooling System Replacement
必要な工具と部品
  1. HP EliteBook x360 830 G6 Cooling System Replacement, Unfasten the back cover: 手順 1、 1の画像 1
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 Cooling System Replacement, Release the clips: 手順 2、 2の画像 1 HP EliteBook x360 830 G6 Cooling System Replacement, Release the clips: 手順 2、 2の画像 2
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 Cooling System Replacement, Release the remaining clips: 手順 3、 2の画像 1 HP EliteBook x360 830 G6 Cooling System Replacement, Release the remaining clips: 手順 3、 2の画像 2
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 Cooling System Replacement, Remove the back cover: 手順 4、 3の画像 1 HP EliteBook x360 830 G6 Cooling System Replacement, Remove the back cover: 手順 4、 3の画像 2 HP EliteBook x360 830 G6 Cooling System Replacement, Remove the back cover: 手順 4、 3の画像 3
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
  5. HP EliteBook x360 830 G6 Cooling System Replacement, Disconnect the battery: 手順 5、 3の画像 1 HP EliteBook x360 830 G6 Cooling System Replacement, Disconnect the battery: 手順 5、 3の画像 2 HP EliteBook x360 830 G6 Cooling System Replacement, Disconnect the battery: 手順 5、 3の画像 3
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternate sides to "walk" the connector out.
  6. HP EliteBook x360 830 G6 Cooling System Replacement, Cooling System: 手順 6、 3の画像 1 HP EliteBook x360 830 G6 Cooling System Replacement, Cooling System: 手順 6、 3の画像 2 HP EliteBook x360 830 G6 Cooling System Replacement, Cooling System: 手順 6、 3の画像 3
    • Using the Phillips #0 screwdriver, remove the seven 3 mm screws from the cooling system.
  7. HP EliteBook x360 830 G6 Cooling System Replacement: 手順 7、 3の画像 1 HP EliteBook x360 830 G6 Cooling System Replacement: 手順 7、 3の画像 2 HP EliteBook x360 830 G6 Cooling System Replacement: 手順 7、 3の画像 3
    この手順で使用する道具:
    購入する
    • Remove the three 3mm captive screws from the fan using the Philips 0 screwdriver.
    • Using needle nose tweezers, gently grab the base of the connection and pull to disconnect.
  8. HP EliteBook x360 830 G6 Cooling System Replacement: 手順 8、 1の画像 1
    • Separate the fan and cooling system from the motherboard.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our HP EliteBook community for help.
作成者
6人の作成者と共同で作成されました。
Bukari
メンバー登録日: 09/01/21
97 ポイント
1ガイドが承認済み
チーム
Gateway, Team 1-2, Saknee Fall 2021 Gateway, Team 1-2, Saknee Fall 2021人のメンバー
GCC-SAKNEE-F21S1G2
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 44
今までの合計 581
