はじめに
A keyboard is necessary for any computer, laptop, or even typewriter in order to operate them. It is key that the keyboard is working at the highest standard so that the HP EliteBook 8470p can be used properly. If there is an issue with the keyboard, it needs to be repaired or replaced.
This 75% form keyboard uses a QWERTY layout and has a pointing stick.
This guide requires the battery and service cover to be removed before starting.
必要な工具と部品
Position the computer upside down with the opening latch facing away from you and the battery facing towards you.
With the laptop latch still facing away from you, slide the left release latch to the left.
Loosen the three captive Phillips screws securing the keyboard to the computer with a Phillips #00 screwdriver.
ある他の人がこのガイドを完成しました。
