はじめに
The fan in this laptop ensures that all the components are at a temperature where they can perform to the user’s standards. It is located inside the laptop in the upper left corner.
A fan that is damaged or broken could lead to overheating and a loss of performance in the laptop. Things to look for are your keyboard feeling warm, the laptop freezing for no apparent reason, and a lack of air dispersed from the laptop's exhaust ports.
This step should be completed after removing the battery and service cover from the underside of the computer.
必要な工具と部品
Position the computer upside down with the opening latch facing away from you and the battery facing towards you.
With the laptop latch still facing away from you, slide the left release latch to the left.
ある他の人がこのガイドを完成しました。
