メインコンテンツにスキップ
HP EliteBook 8470p Case/Service Cover Replacement
  1. HP EliteBook 8470p Case/Service Cover Replacement, Battery: 手順 1、 1の画像 1
    • Position the computer upside down with the opening latch facing away from you and the battery facing towards you.
    • If the battery is “swollen” or the shape is irregular, stop whatever you are doing and allow the battery to slowly discharge itself before removing it from the laptop casing. Click the link to learn how to replace and dispose of a “swollen” battery, What to do with a swollen battery.
  2. HP EliteBook 8470p Case/Service Cover Replacement: 手順 2、 1の画像 1
    • Slide the battery latch positioned to the right over to the right side. Hold it there.
  3. HP EliteBook 8470p Case/Service Cover Replacement: 手順 3、 1の画像 1
    • With the latch opened, pull the battery out of its socket firmly.
    • There will likely be some resistance. However, if you find it to be excessive, the latch may not be properly opened.
  4. HP EliteBook 8470p Case/Service Cover Replacement, Case/Service Cover: 手順 4、 1の画像 1
    • With the laptop latch still facing away from you, slide the left release latch to the left.
    • Some models may have a screw installed on this latch, if so, be sure to remove it first to avoid damaging the latch.
  5. HP EliteBook 8470p Case/Service Cover Replacement: 手順 5、 2の画像 1 HP EliteBook 8470p Case/Service Cover Replacement: 手順 5、 2の画像 2
    • Slide the door away from you, toward the opening latch.
    • Lift the door upwards away from the computer.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Owen Bangs
メンバー登録日: 10/25/22
656 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 5-3, Sinclaire Fall 2022 UMass Dartmouth, Team 5-3, Sinclaire Fall 2022人のメンバー
UMASSD-SINCLAIRE-F22S5G3
5 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 23
今までの合計 391
