はじめに
If the battery is running low or does not work any more, use this guide to replace it.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
必要な工具と部品
Use a Phillips #00 screwdriver to remove the seven screws holding the battery in place.
7 の人々がこのガイドを完成させました。
5 件のコメント
Thanks a lot for the information!
Thanks for the help. Successfully change my battery.
One problem that people might run into is the device not recognizing the battery firmware if it is an aftermarket battery and not a genuine HP one. Where the device will work but only if it is plugged into the charger. It even shows the battery charging but very slowly. If you disconnect the charger the device will instantly shut off. What is the fix for that?
Why must the flex cable be disconnected? If you are able to secure the screen in proper position it does not appear that it would interfere with the battery change.
Na vervanging batterij aangesloten op charger, witte led knippert enkele malen en gaat dan uit. De batterij indicator in windows geeft niet aan dat er geladen wordt. Wat zou de oorzaak kunnen zijn?
