はじめに
We are going to help you remove and replace a component of your HP Chromebook CB2L. The component that this guide helps you with is the Audio Port of the HP Chromebook CB2L. Please take a look at this troubleshooting page to confirm that this component needs replacement.
必要な工具と部品
Flip Chromebook over so that the bottom panel is facing upward.
Use the plastic opening tool to remove the blue panel.
ある他の人がこのガイドを完成しました。
