はじめに
If the touchpad on your HP Chromebook 14-q063cl is not responding to your fingers, it may need to be replaced. Use this guide to remove and replace your touchpad.
The touchpad is one of the main components of your laptop that you use to give it commands and complete tasks. If the touchpad is not working, even basic tasks cannot be properly completed.
For more information on troubleshooting issues for the touchpad, take a look at the Troubleshooting page for assistance.
Before beginning this repair, turn off your device and unplug from the charger.
必要な工具と部品
Flip the laptop upside down so that the bottom is facing upwards.
Use Phillips #0 screwdriver to remove nine 6.7 mm screws from the bottom panel.
To safely remove the ribbon cable securing the touchpad ribbon cable is a ZIF connector, use the angled tweezers to lift up the plastic flap of the ZIF connector.
Use the angled tweezers to pull the touchpad ribbon cable from the connector on the motherboard.
