はじめに
If the screen on your HP Chromebook 14-q063cl is damaged or has become inoperable, your display may need to be replaced. Use this guide to remove and replace the display screen.
The display screen is the component of the laptop which allows you to see and interact with the functions of the laptop. When the display is not working, has sustained damages, or features large blemishes, your ability to properly and effectively use your laptop is compromised.
For more information on troubleshooting issues for the display assembly, take a look at the Troubleshooting page for assistance.
Before beginning this guide, power down your Chromebook and unplug it from the power outlet.
必要な工具と部品
Flip the laptop upside down so that the bottom is facing upwards.
Use Phillips #0 screwdriver to remove nine 6.7 mm screws from the bottom panel.
Use a spudger to remove the white adhesive covers from the left and right corners of the screen. Set them to the side.
