メインコンテンツにスキップ
HP Chromebook 11A G6 EE Webcam Cable Replacement
必要な工具と部品
  1. HP Chromebook 11A G6 EE Webcam Cable Replacement, Microphone/Webcam Cable: 手順 1、 3の画像 1 HP Chromebook 11A G6 EE Webcam Cable Replacement, Microphone/Webcam Cable: 手順 1、 3の画像 2 HP Chromebook 11A G6 EE Webcam Cable Replacement, Microphone/Webcam Cable: 手順 1、 3の画像 3
    • Remove six 6.6 mm screws from the back case using a Phillips #1 screwdriver.
    • Remove two 8.7 mm screws from the back case using a Phillips #1 screwdriver.
    • Turn the computer over and open it as if you are going to use it.
  2. HP Chromebook 11A G6 EE Webcam Cable Replacement: 手順 2、 3の画像 1 HP Chromebook 11A G6 EE Webcam Cable Replacement: 手順 2、 3の画像 2 HP Chromebook 11A G6 EE Webcam Cable Replacement: 手順 2、 3の画像 3
    • Use the iFixit opening tool to get between the keyboard bezel and the outer edge of the laptop.
    • There are several clips on all sides that will need to be released. You'll hear and feel a pop as each clip is released.
    • Move the opening tool or spudger around the perimeter until you unclipped the keyboard on all sides.
    • This will require a little force. The only thing you don't want to do is push the spudger too deep under the keyboard. You could damage the internals if you do.
  3. HP Chromebook 11A G6 EE Webcam Cable Replacement: 手順 3、 2の画像 1 HP Chromebook 11A G6 EE Webcam Cable Replacement: 手順 3、 2の画像 2
    • Carefully lift the top of the keyboard up to access the ribbon cables connecting it to the device.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on each connector. Then, pull the cables out.
    • Lift the keyboard off the to remove.
  4. HP Chromebook 11A G6 EE Webcam Cable Replacement: 手順 4、 3の画像 1 HP Chromebook 11A G6 EE Webcam Cable Replacement: 手順 4、 3の画像 2 HP Chromebook 11A G6 EE Webcam Cable Replacement: 手順 4、 3の画像 3
    • Use the opening pick around the edges of the screen bezel carefully to remove.
    • Remove screen bezel.
  5. HP Chromebook 11A G6 EE Webcam Cable Replacement: 手順 5、 3の画像 1 HP Chromebook 11A G6 EE Webcam Cable Replacement: 手順 5、 3の画像 2 HP Chromebook 11A G6 EE Webcam Cable Replacement: 手順 5、 3の画像 3
    • Peel back the tape that secures the webcam to the left display panel hinge.
    • Gently slide out the webcam connector.
    • Take note of the routing of the webcam connector cable
  6. HP Chromebook 11A G6 EE Webcam Cable Replacement: 手順 6、 1の画像 1
    • Peel back the retention tape.
    • Disconnect the webcam cable from webcam board.
    • Remove the webcam cable from the routing channel and retention tape from the display enclosure.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Scott
メンバー登録日: 09/06/23
365 ポイント
2のガイドは作成済み
チーム
Austin Community College, Team 8-1, Watkins Fall 2023 Austin Community College, Team 8-1, Watkins Fall 2023人のメンバー
AUSTINCC-WATKINS-F23S8G1
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 87
