メインコンテンツにスキップ
HP Chromebook 11A G6 EE WLAN Replacement
必要な工具と部品
  1. HP Chromebook 11A G6 EE WLAN Replacement, Keyboard: 手順 1、 3の画像 1 HP Chromebook 11A G6 EE WLAN Replacement, Keyboard: 手順 1、 3の画像 2 HP Chromebook 11A G6 EE WLAN Replacement, Keyboard: 手順 1、 3の画像 3
    • Remove six 6.6 mm screws from the back case using a Phillips #1 screwdriver.
    • Remove two 8.7 mm screws from the back case using a Phillips #1 screwdriver.
    • Turn the computer over and open it as if you are going to use it.
  2. HP Chromebook 11A G6 EE WLAN Replacement: 手順 2、 3の画像 1 HP Chromebook 11A G6 EE WLAN Replacement: 手順 2、 3の画像 2 HP Chromebook 11A G6 EE WLAN Replacement: 手順 2、 3の画像 3
    • Use the iFixit opening tool to get between the keyboard bezel and the outer edge of the laptop.
    • There are several clips on all sides that will need to be released. You'll hear and feel a pop as each clip is released.
    • Move the opening tool or spudger around the perimeter until you unclipped the keyboard on all sides.
    • This will require a little force. The only thing you don't want to do is push the spudger too deep under the keyboard. You could damage the internals if you do.
  3. HP Chromebook 11A G6 EE WLAN Replacement: 手順 3、 2の画像 1 HP Chromebook 11A G6 EE WLAN Replacement: 手順 3、 2の画像 2
    • Carefully lift the top of the keyboard up to access the ribbon cables connecting it to the device.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on each connector. Then, pull the connector out.
    • Remove the keyboard and set aside.
  4. HP Chromebook 11A G6 EE WLAN Replacement, WLAN: 手順 4、 3の画像 1 HP Chromebook 11A G6 EE WLAN Replacement, WLAN: 手順 4、 3の画像 2 HP Chromebook 11A G6 EE WLAN Replacement, WLAN: 手順 4、 3の画像 3
    • Use the tip of a spudger to disconnect the wireless antenna cable labeled "1/MAIN" from the "Main" terminal on the WLAN module.
    • Use the tip of a spudger to disconnect the wireless antenna cable labeled "2/AUX" from the "Aux" terminal on the WLAN module.
    • When disconnecting or attaching these antennae, pull straight up on them. They act like snap buttons when releasing or attaching them.
  5. HP Chromebook 11A G6 EE WLAN Replacement: 手順 5、 3の画像 1 HP Chromebook 11A G6 EE WLAN Replacement: 手順 5、 3の画像 2 HP Chromebook 11A G6 EE WLAN Replacement: 手順 5、 3の画像 3
    • Remove the 2.5 mm screw that secures the WLAN module to the motherboard using a Phillips #1 screwdriver.
    • Remove the WLAN module by tilting the module up and pulling the module away from the slot at a slight angle.
終わりに
作成者
3人の作成者と共同で作成されました。
William S
メンバー登録日: 09/25/22
575 ポイント
5のガイドは作成済み
チーム
Austin Community College, Team 13-2, Watkins Fall 2022 Austin Community College, Team 13-2, Watkins Fall 2022人のメンバー
AUSTINCC-WATKINS-F22S13G2
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 121
