メインコンテンツにスキップ
HP Chromebook 11A G6 EE Touchpad Replacement
必要な工具と部品
  1. HP Chromebook 11A G6 EE Touchpad Replacement, Keyboard: 手順 1、 3の画像 1 HP Chromebook 11A G6 EE Touchpad Replacement, Keyboard: 手順 1、 3の画像 2 HP Chromebook 11A G6 EE Touchpad Replacement, Keyboard: 手順 1、 3の画像 3
    • Remove six 6.6 mm screws from the back case using a Phillips #1 screwdriver.
    • Remove two 8.7 mm screws from the back case using a Phillips #1 screwdriver.
    • Turn the computer over and open it as if you are going to use it.
  2. HP Chromebook 11A G6 EE Touchpad Replacement: 手順 2、 3の画像 1 HP Chromebook 11A G6 EE Touchpad Replacement: 手順 2、 3の画像 2 HP Chromebook 11A G6 EE Touchpad Replacement: 手順 2、 3の画像 3
    • Use the iFixit opening tool to get between the keyboard bezel and the outer edge of the laptop.
    • There are several clips on all sides that will need to be released. You'll hear and feel a pop as each clip is released.
    • Move the opening tool or spudger around the perimeter until you unclipped the keyboard on all sides.
    • This will require a little force. The only thing you don't want to do is push the spudger too deep under the keyboard. You could damage the internals if you do.
  3. HP Chromebook 11A G6 EE Touchpad Replacement: 手順 3、 2の画像 1 HP Chromebook 11A G6 EE Touchpad Replacement: 手順 3、 2の画像 2
    • Carefully lift the top of the keyboard up to access the ribbon cables connecting it to the device.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on each connector. Then, pull the connector out.
    • Remove the keyboard and set aside.
  4. HP Chromebook 11A G6 EE Touchpad Replacement, Touchpad: 手順 4、 3の画像 1 HP Chromebook 11A G6 EE Touchpad Replacement, Touchpad: 手順 4、 3の画像 2 HP Chromebook 11A G6 EE Touchpad Replacement, Touchpad: 手順 4、 3の画像 3
    • Peel back the tape that secures the battery cable connector to the system board.
    • Using the pointy end of the spudger, lift the tab lock up that holds the ribbon cable in place.
    • Slide the battery cable out from the connector.
  5. HP Chromebook 11A G6 EE Touchpad Replacement: 手順 5、 3の画像 1 HP Chromebook 11A G6 EE Touchpad Replacement: 手順 5、 3の画像 2 HP Chromebook 11A G6 EE Touchpad Replacement: 手順 5、 3の画像 3
    • Remove the three 2.5 mm screws that secure the touchpad and touchpad bracket to the keyboard/top cover using a Phillips #1 screwdriver.
    • Remove the three 2.0 mm screws that secure the touchpad to the keyboard/top cover using a Phillips #1 screwdriver.
  6. HP Chromebook 11A G6 EE Touchpad Replacement: 手順 6、 3の画像 1 HP Chromebook 11A G6 EE Touchpad Replacement: 手順 6、 3の画像 2 HP Chromebook 11A G6 EE Touchpad Replacement: 手順 6、 3の画像 3
    • Using a spudger, remove the touchpad bracket.
    • Push up on the touchpad from the keyboard side and remove the touchpad.
終わりに
作成者
3人の作成者と共同で作成されました。
William S
メンバー登録日: 09/25/22
575 ポイント
5のガイドは作成済み
チーム
Austin Community College, Team 13-2, Watkins Fall 2022 Austin Community College, Team 13-2, Watkins Fall 2022人のメンバー
AUSTINCC-WATKINS-F22S13G2
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 141
