はじめに
If the device is failing to transmit sound it may be necessary to replace the headphone jack. The most difficult step will be soldering the headphone jack, it is important to make sure you have all tools required and follow the instructions precisely.
必要な工具と部品
Push out the battery connector using the spudger.
Swing the battery connector clear of the connector socket.
もう少しです!
終わりに
